Truck won't turn over? - YotaTech Forums
Go Back   >
Pre 84 Trucks 1st gen pickups
LinkBack Thread Tools Search this Thread
Old 12-22-2008, 06:38 PM   #1
fyreandwater's Avatar
At times my truck decides it doesn't want to turn over. Usually when it's cold or I haven't driven it for awhile the starter doesn't seem to work. If I roll the truck and pop the clutch it will turn over. The batter cables are all fine. I'm thinking there's a dead spot on the starter and I need a new one. Has anyone else had this problem?
fyreandwater is offline   Reply With Quote
Old 12-22-2008, 06:58 PM   #2
PDX_1ton's Avatar
Yes. Your starter could be on the way out. You can pull it and do a home diagnosis if you have a multi meter and the Manual. Do you have both?
PDX_1ton is offline   Reply With Quote
Old 12-22-2008, 07:08 PM   #3
scooper's Avatar
If you dont, just take it to a local parts store, they will usually check them for free. It's really easy to take out, 2 bolts. Just make sure you disconnect the battery or it could be a shocking experience.
scooper is offline   Reply With Quote
Old 12-23-2008, 05:04 PM   #4
I'll take it out and have it tested. Thanks for confirming what I thought was wrong.
Old 12-23-2008, 06:07 PM   #5
slacker's Avatar
yep if your battery is good and starter is good .. should
" er' er' er' errr err' err er er " anyway .
slacker is offline   Reply With Quote
Old 12-27-2008, 09:45 AM   #6
Ron Helmuth's Avatar
note that a lot of times it is just the contacts of the starter. Fairly easy to replace and not all that expensive. 4crawler sells them. Or shops that just sell contacts could match to what you have...
sorry to be butting in over here but this is common for older Yota starters of all eras/vehicles.
Ron Helmuth is offline   Reply With Quote
Old 12-28-2008, 07:10 AM   #7
I haven't taken my starter off yet because it won't quit snowing long enough. We have about 3' on the ground. Had to move my truck today to plow. It was -14 F last night and I jumped in and my truck started without any problems. My 25 year old Yota continues to amaze me. I will add though that with 33x12.50's it's a real pig in the snow and ice. Too much surface area for so little weight.
Old 12-29-2008, 08:44 AM   #8
red1983's Avatar
Quote:
that -14 day my truck did not start...
red1983 is offline   Reply With Quote
Old 12-29-2008, 08:50 AM   #9
red1983's Avatar
Also, I got some sandbags for the back of my truck at kroegers... I really helped with the deep snow... I got 4 bags for 18 bucks, adding 240 lbs to the back.
Old 01-03-2009, 06:16 AM   #10
Hopefully we won't see it that cold again for awhile, but it looks like it might snow again today. I can try some weight to help with my traction, but with 33x12.50's and lockers front and rear it doesn't do well on the snow packed roads.
97 4runner heat Not working! Need help pelase Cesarl74 95.5-2004 Tacomas & 96-2002 4Runners 8 04-23-2016 07:07 PM
01 Ignition Key will not turn off all the way alfonz33 95.5-2004 Tacomas & 96-2002 4Runners 9 11-16-2015 10:21 AM
Why is Battery Leaking? bigblue82 General Electrical & Lighting Related Topics 10 07-06-2015 09:27 AM
94 toyota pickup will crank but not start rbravo1 86-95 Trucks & 4Runners 4 06-29-2015 02:34 PM
Steering Box of 85 Diesel Pickup compared to 85 Gas Pickup GreenLion 84-85 Trucks & 4Runners 1 06-28-2015 07:05 AM
Tags
1983, 60, 85, 90, doesnt, forumsengine, pickup, problem, reasons, starter, toyota, truck, turn, turnover, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
