YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > Pre 84 Trucks
Sign in using an external account
Register Forgot Password?
Search
Pre 84 Trucks 1st gen pickups
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-02-2007, 11:04 PM   #1 (permalink)
Personal Sales Rating: (0)
Transfer case output shaft seal and bearing?
My yota is spilling a little gear oil. The front output shaft is leaking where the driveshaft mounts to the transfer case, and there is about 1/4 in of slop in the shaft going into the case when 4wd is not engaged (don't know if this is normal or not). I believe I am going to have to replace the output shaft bearing and seal, but don't know how big of a job I am getting myself into. Do you have to open the case to replace this bearing, or is this something you can do from the outside? The 4wd works, but I havn't tried it for long. I have been restoring this truck for the last 2 years, ran out of money for a while, now I'm finishing it. I havn't drove it for more than 2 miles the whole time I owned it. Its got the original 80 4spd tranny, and transfer case, if that matters. Thanks in advance!
__________________
1980 pickup, longbox, rebuilt 22r, weber carb, 4speed, 4x4, just painted canteen metallic green
joshd is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-03-2007, 12:59 AM   #2 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
its been awhile since Ive had a gear drive case apart, but I'm pretty sure you have to take the back half of the case off to get the front drive out, you should be able to replace the seal with out splitting the case
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 11-03-2007, 07:59 PM   #3 (permalink)
Fossilizing
Personal Sales Rating: (3)
Staff
dropzone's Avatar
Here is a link to a Video on transfercases that Trail-Gear did. Don't think there is sound but thought that it might help you out:
http://www.trail-gear.com/videos/toy-tcase.wmv
Here is the link to the 4.7 gear install (know it is not what you are doing) but pictures help to show some of the work involved with transfer case...http://trail-gear.com/tech/470install/470inst.html
__________________
~robb
'81 Toyota Trekker The B4Runner
Mini FAQ/Ideas
PNW wheeler group: Gitout.Com
dropzone is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
bearing, case, change, front, output, play, rear, replace, replacing, seal, seals, shaft, toyota, transfer, transfercase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What size is the nut on the output shaft of the transfer case? jagger_snitt 86-95 Trucks & 4Runners 4 10-22-2007 06:33 AM
Rear output shaft seal Spinnbait 86-95 Trucks & 4Runners 5 06-18-2007 08:28 AM
Replacing transfer case front output seal? gapguy 95.5-2004 Tacomas & 96-2002 4Runners 9 08-03-2006 06:39 PM
Front output shaft seal help 40_Below 95.5-2004 Tacomas & 96-2002 4Runners 4 08-11-2005 10:51 AM
Transfer Case Output Bearing Change Toyo_Master 95.5-2004 Tacomas & 96-2002 4Runners 7 02-29-2004 07:38 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
