Tire Fitment?
1 Post
Tire Fitment?
Got an 82 Pickup and I want to toss some rubber on it to replace the **** that's currently there.
It's stock ride height far as I know. Can I toss some 33x12.50 tires on it?
Will I need to change the rims?
I'd like to run 37x12.50s once I do the suspension over, should I widen the axles or use spacers or what?
FYI, the rear has a flat bed.
Likely 31x10.50 without a lift. You can fit 33s with a few inches of lift (suspension or body). Stock rims are likely 6" wide, a 33x10.50 works well on those:
http://www.4crawler.com/4x4/BFG_AT_KO.shtml
Probably need an 8" rim for 12.50s.
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
