sway bar - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-19-2009, 09:28 PM   #1 (permalink)
corteznewbie's Avatar
Send a message via Yahoo to corteznewbie
sway bar
any one know if the 82 4x4 had a sway bar? because mt steering is kinda out of wack. when i drive it wonders
corteznewbie is offline
Old 10-19-2009, 09:56 PM   #2 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
An anti-sway bar is not gunna make you wander. Anti-sway bars help keep body roll down when cornering. You probably want to get an alignment and check your front brakes.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Old 10-19-2009, 09:59 PM   #3 (permalink)
algranger's Avatar
Yeah you need an alignment, its easy to do yourself its easy with a straight axle, just use a tape measure. Bring the fronts together about 1/4"
Yes your truck did come with a sway bar but it doesnt really do anything, your old springs get tired and stiffen up and give the same effect
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 10-19-2009, 10:04 PM   #4 (permalink)
what about adajusting the gearbox
Old 10-19-2009, 10:20 PM   #5 (permalink)
algranger's Avatar
Why would you want to do that?
By adjusting i assume you mean reindexing...?
__________________
I said lie, for me
Old 10-19-2009, 10:25 PM   #6 (permalink)
well when i driv feels like the front end is floaten. and theres sum play in the steering when i'm park and turn the wheel
Old 10-19-2009, 10:49 PM   #7 (permalink)
4x4YOTA's Avatar
check your knuckles make sure there not loose and your wheel bearings... make sure the preload is right
__________________
81 Toyota 4x4: 22R, weber carb, long tube header w/custom exhaust, L45 4 speed, 4.56 V6 3rds, TG highsteer, RUF w/sky shackle, custom rear springs w/shackle, 2" BL, 32x11.50x15 BFG MTs on 15x7s(street), 37x13.50x15 DC FC2s on 15x8s(trail), ARB air compressor, KC lights, topper...
4x4YOTA is offline
Old 10-19-2009, 10:56 PM   #8 (permalink)
peow130's Avatar
Check balljoints, though it could be your gearbox.
Take it to an alignment shop.
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5
1978 Camaro Z28, 454 Big Block V8 with a 4 Speed.
peow130 is offline
Old 10-19-2009, 11:02 PM   #9 (permalink)
knuckles been rebuilt last year cost me 700 bucks they said everything to specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
