Pre 84 Trucks 1st gen pickups
Stock axles with 33's and 4.7 t-case gears?
Old 05-05-2012, 03:36 AM
dansouthwick's Avatar
Hey guys, i tried searching but didn't get much help. With 33" tires, 4.7 t-case gearing, 4.88 diff gears will the stock axles hold up, or should I think about upgrading to chro-moly axles/birfields?
Old 05-05-2012, 04:30 AM
waskillywabbit's Avatar
At the mall no, wheeling it yes on the front.
:wabbit2:
Old 05-05-2012, 08:22 AM
Sorry, i'm not getting what your saying. I have 33"tires and 4.88 gears with stock axles. If I put 4.7 t-case gears in it should i also upgrade the axle shaft/birfields or will the stock axles be able to handle it?
Old 05-05-2012, 08:41 AM
BoredOutnJackdUp's Avatar
You will be fine.
Old 05-06-2012, 08:44 AM
4x4YOTA's Avatar
you will be fine I ran 33s with 4.88s and dual 2.28 cases and never had an issue... when you get a locker up front you will want to upgrade your axles and birfs
Flying91
45
04-11-2024 04:39 PM
oldirtydirt
02-23-2020 09:30 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
Quick Reply: Stock axles with 33's and 4.7 t-case gears?
