Staring Issue
Staring Issue
so my truck has some starting issues sometimes... I put the key in the ignition to try to turn it on battery is fully charged cause everything turns on but when I try to crank the engine nothing happens not even a sound. Turn the key to start doesn't even try to start what could the issue be? It act's up sometimes I turn the key and bamn it goes
I know you have checked all the wires right? nothing loose not even a ground? Becouse we all know the gauges take a lot less amps than starting the motor. so that leaves us with not getting the right amps to the starting system. question to you is do you have an ohmetter or ammetter
Check to make sure your battery is putting out enough juice. Lights may come on, but the starter requires more amperage that lighting and other accessories. If the battery is good, check the connection on your starter. Check it's ground and it's feed with a meter. You can jump the starter by putting the ignition to the "on" position and take jumper cables directly to the starter. Attach your ground and tap it with the feed with the positive feed from your battery. It should start it right up if the starter is good.
If those seem to be good then your move on and check your ignition wiring for loose wires and grounds.
crammit442
7
11-29-2017 12:30 PM
rjtrials
08-06-2015 07:25 PM
