skyjacker lift kit 5," 83pickup
I have 4" suspension and 3" body, running 35's on my 85. It rubs when turned and bent, but never when its just one or the other. I would suggest the 4" if you wish to run 35's. I mean, lift is up and good to go, not enough is a waste of money, because you just want more.
When I got my front Trail Gear springs they were about $45 to ship from California to Oregon.
I may use the NWOR springs on a Trailer project for my Tacoma...
#25
Yeah I know shipping wouldn't be cheap, but if they are sittig around taking up space and you would give them away then what's $100? I know that won't happen, but it's always worth a try! I plan to pick up some springs this summer and Trail gear is what I'll be ordering.
#26
I installed the Skyjacker 5" kit on my 82 when I first started it's build-up.
It easily clears 35's and came with shims to correct pinion angles as well as a dropped pitman and torque rod riser.
It was a good lift and last forever but it's a bit stiff for rock crawlin.
This photo is with the SJ lift and like 30" (?) tires...
Here's the same lift with 35's...
the rears stuffd into the wells perfectly when compressed.
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
kirkrunner
07-27-2015 07:59 PM
