Rust Repair by a first timer :D (warning: big pics) - YotaTech Forums
Go Back   >
Pre 84 Trucks 1st gen pickups
LinkBack Thread Tools Search this Thread
Old 05-17-2009, 08:16 PM   #1
Dieselfuel12v's Avatar
I've never done bodywork or rust repair on anything, just mechanical things. My truck had what has to be one of the worst rust repair jobs ever, on the corner of the wheel well. It was a piece of carpet, with bondo on it and painted over, and expansion foam filling the wheel well..... I'm no bodywork genius, but that was a nasty "repair". So I cut the whole piece out and welded in a piece I fabbed up. It was a tricky bend, since it had about 5 different directions to follow. Its not perfect yet, I still need to fill a few spots in the joint with weld and grind it smooth, but its nearly there. No rust, decent looks, what more can you ask for on a wheeler.
Side note: I need some advice on my middle body mounts (the ones right below the door hinge). There completey useless, like the floor pan is sitting on the frame in that spot. The mounts are loose from the body. Any tips on getting some new metal in for them?
Dieselfuel12v is offline   Reply With Quote
Old 05-17-2009, 08:24 PM   #2
toyospearo's Avatar
Nice work!!
I would like to see a pic of your flatbed!
toyospearo is offline   Reply With Quote
Old 05-20-2009, 05:15 PM   #3
Was bored just now, so I got up on this small rock. Mainly to test my front brake line length, but you can see the flatbed in the pics.
Old 05-20-2009, 05:20 PM   #4
bigt's Avatar
niice yota man!! and good repair.. im pretty much rebuild a suzuki samurai Long wheel based from scratch !!!
i like seeing welding!
bigt is offline   Reply With Quote
Old 05-21-2009, 06:22 AM   #5
scooper's Avatar
Turned out pretty nice. I dont think I care much for the foam in it, but the overall look turned out excellent. Great job. Did you get ALL teh rust off of the inner fenderwell before you closed/sprayed/painted it up? IF not, that new paint won't last too long.
scooper is offline   Reply With Quote
Old 05-21-2009, 10:41 AM   #6
I took all the foam out. The prior repair was what used that foam. What I did was wire wheeled all the buildup on the inside, then cleaned it with acetone, and put two layers of rust paint on for now, until I get all the rust repair done. I'm gonna paint the whole cab silver or something later.
My middle body mounts are completely rusted off, I need to figure out the best way to weld in some new metal there to support the cab. It's basically resting on the frame there.
Old 05-21-2009, 11:25 AM   #7
toyospearo's Avatar
GREAT REPAIR!!
That is a great looking truck.
I am in the process of designing a flatbed for my 94. Thanks for the photo of that.
22re blown head gasket with rust tylermx71 86-95 Trucks & 4Runners 13 09-29-2015 09:49 PM
Justdifferentials / Nitro Gear 99 Land Cruiser 100 Series, SC'd, 4.88, lockers, etc justdifferentials Just Differentials 3 09-29-2015 06:30 PM
The birth of the orange rocket presto30 Pre 84 Trucks (Build-Up Section) 0 09-15-2015 10:41 AM
Pacesetter tfx catback exhaust Zach_trun Product Reviews 2 09-14-2015 07:16 PM
Tags
acura, integra, paint, pics, repair, repairing, rust, rusted, samurai, suzuki, threads, toyota, truck, wheel, worst
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
