Sign in using an external account
| Pre 84 Trucks 1st gen pickups |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (1)
rears up front
__________________
81 Toyota PU 4x4 Daily Driver 81 Toyota PU SR5 4x4 Parting out (pm for info) |
#2 (permalink) |
Personal
Sales Rating: (0)
i just finished my 63'''s in the rear so this is my next project... ive been told to find another rear spring set and take leaves from it to make 6 total leaves for each spring...?
#3 (permalink) | |
Personal
Sales Rating: (2)
Quote:
- http://www.4crawler.com/4x4/4R_suspe...l#Update-part3
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad - YotaTech discount code Gettin'Off 4WD Club |
#4 (permalink) | |
Personal
Sales Rating: (1)
[OP]
Quote:
__________________
81 Toyota PU 4x4 Daily Driver 81 Toyota PU SR5 4x4 Parting out (pm for info) Last edited by 4x4YOTA; 11-25-2008 at 07:57 PM. |
#5 (permalink) |
Personal
Sales Rating: (1)
[OP]
how much lift will that give you
__________________
#6 (permalink) | |
Personal
Sales Rating: (2)
Quote:
- http://www.4crawler.com/4x4/4R_suspe...l#Update-part2
__________________
#7 (permalink) |
Personal
Sales Rating: (1)
[OP]
ok great your write up helps me out alot! Im gonna run as close to the exact leaf pack you are to get about the same .5-1" lift I am looking for
__________________
81 Toyota PU 4x4 Daily Driver 81 Toyota PU SR5 4x4 Parting out (pm for info) Last edited by 4x4YOTA; 11-25-2008 at 08:00 PM. |
#8 (permalink) |
Personal
Sales Rating: (1)
[OP]
OK so anther question can I do rears up front but use my stock front main leaf so I don't have to buy banana shackles and keep the overall length the same for steering or does that defeat the whole purpose?
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
just buy some pro comp springs for the front they are cheap
__________________
. . . DIRTY DIESEL She aint purrin, She's damn sure growlin . . . . |
#10 (permalink) |
Personal
Sales Rating: (0)
Id like to know also
__________________
02 KLX300 Dual Sported (Daily Driver) 85 4runner:Chevy 63's- RUF-Crossover-5speed swapped-Dual cases w/marlin adapter-5.29's-Marlin Rear Elocker-Longfields 30 spline/aussie locker front-Rola roof rack-8K smitty built winch-IFS Rear axle-35" BFG KM2's-Gray Interior from an 87-4X Innovations internal cage Build Thread |
#11 (permalink) |
Personal
Sales Rating: (1)
[OP]
they give me more lift than I want I want to be able to use what I have and just add to it rather than start over
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
just dont use blocks in ANY situation.
__________________
2001 Ford F-150 6" lift 315x85x16 tires. (37x13.50s???) 4.6L V8 bumping stereo I love it MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? the toyota is gone... its been fun.. |
#13 (permalink) |
Fossilizing
Personal
Sales Rating: (3)
Staff
here is a tread that might give you some other ideas:
Rears up Front Frequently asked Questions link
__________________
~robb '81 Toyota Trekker The B4Runner Mini FAQ/Ideas PNW wheeler group: Gitout.Com |
#14 (permalink) |
Personal
Sales Rating: (0)
It's more complex than just putting a set of rear leaves up front. You definitely need an aftermarket shackle, around 5" eye to eye, you need to relocate the shock hoops, a drop front hanger helps a lot, and if you build this pack to only yield 1" of lift it will be extremely under-sprung and ride very soft, often reverse arching the springs. You might want to consider some $160 OME springs, because by the time it's all said and done you will have spent over that on your RUF swap, I promise. Also, different rears offer different amounts of lift, as Roger mentioned in his very well written article posted above.
#15 (permalink) |
Personal
Sales Rating: (1)
[OP]
see this is what I am looking for!
I was also wondering about getting a rear set and just adding them to my stock front main leaf because the rears have more arch then the fronts here are my springs
__________________
#16 (permalink) |
Personal
Sales Rating: (1)
[OP]
what about using YJ leafs up front will that work?
__________________
#17 (permalink) |
Personal
Sales Rating: (0)
You could just get some random leaf packs that are 2 1/2" wide and start adding to your stock pack, sure. It'll probably help with the lift, but I'm sure it'll ride pretty stiff. I see you already have some pretty long shackles, so those would probably work better with a more arched leaf pack. Just start experimenting, it's way more fun than surfing the forums all day to see what other people have done.
Here's my rears up front... ![]() ![]() ![]() 40s with lots of trimming, probably 5-6" lft. Last edited by oldgold3vze; 11-28-2008 at 02:15 PM. |
#18 (permalink) |
Personal
Sales Rating: (0)
^ what did you add to make your spring pack? what are you doing for rears? chevies?
#19 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Spring pack from top to bottom: -1980 rear -1980 rear -trimmed down 89 pick up rear -1980 rear with clamp -trimmed down 89 -trimmed down 89 The 1980 rear leaves have way more un weighted arch than the 84-89. My first rears up front pack used the main leaves from an 88 4runner, and I got about 2" less lift, but it was only a 5 leaf pack. Rears are chevys with a 6" shackle and an (ahem) 1" block. The bed of the truck sits 100% perfectly level, that's part of the reason I used the block, plus my u-bolts had about 1" of exposed threads, and I'm trying to make sure those 40s don't rub. Last edited by oldgold3vze; 11-29-2008 at 09:49 AM. |
#20 (permalink) |
Personal
Sales Rating: (1)
[OP]
ok so I guess what I have decided is just get a set of 3" pro comp leafs and mix them with my stock leafs to get a softer and lower ride for cheap
__________________
| Tags |
| 4x4, banana, front, give, leaf, leafs, lift, rear, rears, ruf, shackle, spring, toyota, toyotas, v6 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| im doing rears up front and i have a question | 85toy | 84-85 Trucks & 4Runners | 11 | 06-06-2008 03:19 PM |
| SAS with rears up front | Kiff | Solid Axle Swaps, All Years | 1 | 04-14-2008 04:08 AM |
| Rears to front question? | ydopen | 84-85 Trucks & 4Runners | 3 | 11-15-2007 02:36 PM |
| Rears up Front | corvettelvr73 | 84-85 Trucks & 4Runners | 5 | 08-06-2007 08:10 PM |
| Rears up Front | corvettelvr73 | 84-85 Trucks & 4Runners | 12 | 05-18-2007 09:12 PM |
