YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-28-2008, 06:07 PM   #1 (permalink)
rottenagenda's Avatar
oil pan
Does any one know where to get a aftermarket oilpan?
MIne keeps leaking from years of over tighting. i have replace the gastet twice. so i need a new a oil pan maybe like a larger one? or stock replacement? maybe a better gasket?
20r 1979 4x4 pu
rottenagenda is offline
Sponsored Links
To remove this ad, register today!
Old 09-28-2008, 06:12 PM   #2 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
http://cpwstore.carpartswholesale.co...294966670+9303
What about the dealer?
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is online now
Old 09-29-2008, 07:01 AM   #3 (permalink)
83
83's Avatar
What are you using for a gasket?
__________________
Zach
'83 Shortbed
83 is offline
Old 09-30-2008, 07:36 PM   #4 (permalink)
coark one from baxters auto
Old 09-30-2008, 07:38 PM   #5 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
use some rtv. The the black can called the "Right stuff" is the best rtv ive used.
itll be a pain to take off again but it aint gonna leak
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 09-30-2008, 07:43 PM   #6 (permalink)
I use permatex rtv ultra black high temp silicone. Never had any problems.
__________________
JASON
Jason is right.
Old 09-30-2008, 07:45 PM   #7 (permalink)
I really like the Right stuff becuase of the easy use nozzle unlike the press ones that are so hard to squeeze once used one time!
Rtv is the way to go IMO
__________________
Old 09-30-2008, 10:48 PM   #8 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Early oil pans have raised valleys, and relied on cork gaskets. Incredibly ineffecient and prone to leaks. PLus, you cannot use RTV on the early pans. It squishes out, and will flatten the raised beads.
Do yourself a favor, and find a used/new oil pan from an 85-95 22R 4x4. The valleys are lowered instead of the raised bead, and merely requires some FIPG (Fill in place gasket; use the Toyota brand stuff it WORKS) to seal properly.
Its a direct swap requiring only a new drain plug and drain plug gasket.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is offline
Old 10-01-2008, 03:29 AM   #9 (permalink)
kyle_22r's Avatar
i never saw any raised beads on the oilpans i've dealt with. the one in my old '79 worked just fine with gray RTV silicone.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 10-01-2008, 07:41 AM   #10 (permalink)
All 79-84 used a raised bead oil pan, while 85-95 used a sunken bead.
They also used a 19mm drain plug 79-84, then switched to a 14mm plug 85-95.
__________________
Old 10-02-2008, 07:44 AM   #11 (permalink)
83
83's Avatar
Yeah....I noticed that the Haynes manual says that pre-84 oil pans need a gasket, otherwise on anything newer you can use RTV. My 83 has the raised surface.....but I used black rtv only...didn't read that until I had already done it. No leaks yet, but we'll see. I guess if there are, I'll look for a later model pan.
__________________
Zach
'83 Shortbed
83 is offline
Old 10-02-2008, 05:28 PM   #12 (permalink)
slacker's Avatar
the trick for best sealing , using RTV .. is to "squirt" out the bead , and let it set .. give it some time to "tack up" and then install the pan .. and be sure not to tighten to much as to "squish" it all out .. and then let it "set up" .. 24hrs is best .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5
MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 10-08-2008, 10:34 AM   #13 (permalink)
yukon6inchlift's Avatar
so what is the general consensus??? i have an 81 leaks bad from everyplace probably lol oil pan,,,gasket- no rtv,,,gasket- with rtv,,,no gasket- only rtv. those are the questions,,,
__________________
I dont care what u drive,,,long as u will wheel it!! lol
yukon6inchlift is offline
Old 10-08-2008, 12:16 PM   #14 (permalink)
Like i said...get an 85+ pan, and use Toyota brand FIPG. Leak cured.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pan mrfarinhight Newbie Tech Section 13 08-26-2008 08:02 PM
converting to Mobil1 next oil change, would you recommend drop the oil pan TC4RNR 86-95 Trucks & 4Runners 28 01-08-2008 08:27 PM
Found the oil leak--oil pan removal? morrison 86-95 Trucks & 4Runners 6 12-31-2007 04:16 PM
getting the oil pan off 352Ford 86-95 Trucks & 4Runners 5 04-12-2006 09:21 PM
Oil pan ? surfersr5 Offroad Tech 1 12-05-2005 10:29 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
