| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | ||||||
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#52 (permalink) |
How to Make your Weber work on a hill
Found this one on a Local 4Wheeler board linked from the Marlin Board:
http://board.marlincrawler.com/index...8356#msg588356 compliments of dropthattaco: Ok, so I have a Weber 32/36 DGAV on my 81 4x4. The Weber works great on the 22r, and picked up a bit of pep and the driveability is loads better than stock. Even gets 18 MPG much to my surprise. Unfortunately, the Weber really does not like going up hills. Deciding this was unacceptable, I took it upon myself to remedy this situation. The problem is the location of the bowl vent. When the truck tilts back, the fuel spills into the air horn, making the truck stall. To fix this there are three things you need to do. First, make sure the float level is AT MOST spec height, preferrably 1-2mm lower. Second, install a fuel pressure regulator. I use this one: ![]() and it's set to 2psi. NO MORE. Third, you need to relocate the fuel bowl vent. This is the hardest part, and the one I'm going to focus on. To relocate the bowl vent: Remove the top of the carb. ![]() You will notice a couple of rectangles that pass through the top. One of these is the the bowl vent. It is the one closest to the fuel inlet, furthest from the choke tower. You will need to plug it. I used JB Weld. Here: ![]() And here it is after the JB weld: ![]() Now you will need to make a vent to replace the one you plugged. Luckily there is a blanked port that isn't used on these carbs. Here's what you do. ![]() Drill some holes in the port to allow the vapors out. You will be able to see your drill bit through the hole in the end. Then you will need to vent the vapor somewhere. The fitting in the end is 3/8" inside diameter, so I bought some copper tube from ACE hardware and hammered it in. ![]() and from the top: ![]() Then I routed it to the stock carb charcoal canister (under the battery) using 3/8" fuel hose. ![]() ![]() And here's the finished product: ![]() Runs up hills like a champ now. Good luck!!!
__________________
#53 (permalink) |
IFS Frame Dimensions
IFS Frame Dimensions Link: http://www.pirate4x4.com/forum/showthread.php?t=599542
__________________
#54 (permalink) |
Extending Rear E-Brake cable when installing IFS Rear End
when installing an IFS rear end in a 79-85 truck your E-Brake cable will be short on each side. SUre you can do some trick stuff like a T-C brake, but this is pretty dang simple:
from Erik's page on 4x4wire:
__________________
#55 (permalink) | |
Dual Purpose Dolley or Jackstand/Tires
Borrowing this idea from Brian aka Waskillywabbit--very cool cheap trick:
Quote:
__________________
#56 (permalink) | |
Convert LSPV to Manual proportioning Valve
this is some awesome tech from this thread: http://pirate4x4.com/forum/showthread.php?t=804330
Quote:
__________________
#57 (permalink) | |
Preventing Crushed Axle tubes
How to help prevent Crushed axle tubes-( from this spring perch/axlw tube thread on Pirate )
-sometimes axle tubes are crushed due to wheel hop of larger tires, overtorquing of the u-bolts: the Symptoms: Quote:
always remember to stitch weld when working on axle tubes to prevent warping
__________________
#58 (permalink) |
Toyota Gear/Differential set Up links
Zuk, a member on this board and several others, is pretty much a master at setting up Toyota Third members.
His website: http://gearinstalls.com/ has several great write ups on setting up diffs Tools needed to set up a Differential: http://gearinstalls.com/gearinstalltools.htm Breaking in Differentials: http://performanceunlimited.com/docu...arbreakin.html Definitions of DIffential terms, pattern examples: http://www.differentials.com/install.html Definitions: Ring & Pinion gears The driveshaft is connected to and drives the pinion gear, which in-turn drives the ring gear at a reduced rate and at a 90 degree angle from the driveshaft. The ring gear is basically connected to the wheels. Backlash This is the term used to describe the "clearance" between the ring & pinion gears and is usually measured in thousandths-of-an-inch by a dial indicator. Example .008-.012" Drive / Coast The drive side of the ring gear is the side of the tooth that is contacted when the vehicle is accelerating / The coast side is the side of the tooth on the ring gear that is contacted when the vehicle is decelerating (during engine-braking). Pattern This refers to the tooth contact area of the gearset; In other words, Where the Ring gear and the Pinion gear "Rub" together. Preload The Pinion bearings and Carrier bearings run a little tight, similar to the way a wheel bearing should be "loaded". The tapered bearings are adjusted to eliminate any play and then they are set a little tighter, making them a little "hard to turn". This is measured by checking the torque required to turn the bearings with a dial torque wrench. Example 15 to 25 in.lbs. Pinion Depth This is set with "pinion shims" and controls how the pinion contacts the ring gear in relation to the axle center. Crush Sleeve A piece of "pipe" that is used to hold the pinion bearings apart and offer some resistance for the pinion nut. The pinion nut must be tightened down, crushing the crush sleeve, until proper pinion preload adjustment is achieved. http://home.4x4wire.com/erik/diffs/ **links pulled from Zuk's site and google.
__________________
#59 (permalink) | ||
22RE ECU diagrams
not getting fuel
http://www.yotatech.com/f115/holy-he.../#post51224581 Quote:
Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 09-09-2009 at 09:34 AM. |
#60 (permalink) |
parts Identification, Parts sources
Toyota Parts Identificaton link
http://www.toyodiy.com Toyota Truck Dismantlers: body parts/axles etc The Toy Man (newberg, OR) http://www.thetoyotaman.com/ MazToy (troutdale, OR)http://maztoy.com/ Davez Off Road: http://www.davezoffroadperformance.com/ Yotayard (colorado) http://www.yotayard.com/home.htm Jim's Got Parts (Denver, CO) http://jimsgotparts.com/ California Mini Trucks (Cali) http://www.calminitruck.com/ NIX99 (washington state) http://nix99.com/ Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/ ToyoKings (FLA) http://www.toyokingsusedparts.com/ Yotatech Classifields :http://www.yotatech.com/f91/ TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3 Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4 Parts Locators: http://www.autopartslocator.com/ http://www.seekautoparts.com/
__________________
#61 (permalink) | |
Driveshaft Tech
Note: Will be adding other stuff soon
**from: http://www.pirate4x4.com/forum/showthread.php?t=772346 **This would probably be great on a trail rig...if you DD your rig a lot, consider getting DS work done professionally Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 09-22-2009 at 08:22 AM. |
#62 (permalink) | ||||
Alignment after High Steer
from this thread: http://www.yotatech.com/f116/hi-stee...stions-192496/
Quote:
Quote:
Quote:
Quote:
__________________
#63 (permalink) |
Head Gasket Issues
**More to follow
:Indications you might have a head gasket leak: http://www.yotatech.com/f116/signs-h...t-leak-193718/
__________________
#64 (permalink) |
Cheap Parts Holder
I picked up a used transmission and transfer case recently to replace the one that took a dump on me...cleaning it up I needed a place to put the bolts and washers, remember that I had bought a magnet parts bowl at harbor freight awhile ago for like a buck or two:
![]() thought it was kind of cool till I realized how small it was as I was grabbing a pop out of the garage fridge and saw all these magnets on the door...hmmmm ![]() looked at all the x-mas cookie tins on the shelf, glanced at the drill. had this a few minutes laterL ![]() ![]() 20 times the capacity with a lid...
__________________
#65 (permalink) | |
Side Marker Clearance Light replacement option
Here is a good, cheap write up on replacing your side marker lights
that Rowdy 235 did a couple of years ago: http://www.yotatech.com/f114/side-cl.../#post50698729 Quote:
__________________
| Tags |
| 22re, alternator, heat, ig, internally, mod, notebook, pipe, pirate, regulated, signal, tach, toyota, truck, weird, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| parental units. any good ideas for me? | dijlop | Off Topic Talk | 63 | 06-12-2007 10:19 AM |
| ideas for bike racks - good or bad | 4biker | Newbie Tech Section | 13 | 06-09-2007 08:38 PM |
| possible mods and ideas to FJ | airrikk17 | FJ Cruiser | 1 | 04-29-2006 08:42 PM |
| good mods for the 2.7 liter | tacoma007007 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-09-2005 06:14 PM |
| Floor mat dilema any good ideas? | UKMyers | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-09-2002 09:14 PM |
