| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ocdropzone's notebook Mods/Links/Upgrades/Ideas
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 03-22-2009 at 06:10 PM. |
#2 (permalink) | ||||
increase Power steering fluid reservoir capacity
txzuk1988:
Not sure what the toy factory reservoir capacity is. But I used it stock with a stock mini truck pump for a while. I simply cut the reservoir in half and added some exhaust tubing to make the tank about 8" tall. Here is the 3.5" exhaust pipe I used 409 SS ![]() more reservoir Information: Quote:
Quote:
Quote:
Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 05-28-2009 at 01:00 AM. |
#3 (permalink) | |
IFS Mounting For High Steer
Quote:
![]() ![]() what you don't want to have happen when you install your high steer:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 03-15-2009 at 01:55 AM. |
#4 (permalink) |
conversion links
metric to inch etc:
http://www.engineeringtoolbox.com/in...ion-d_751.html
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#5 (permalink) | ||
thread links
Google for TOyota Websites
Flat Bed Pics: http://www.pirate4x4.com/forum/showt...ferrerid=89727 Toyota Front Bumper pics http://pirate4x4.com/forum/showthrea...t=front+bumper Great info On color schemes etc: Toyota Reference.com SR-5 Info SR-5.com Service Manual Links: http://ncttora.com/fsm/index.html 4Crawler Off Road Toyota CHeap Tricks Rear Disk Conversion Links/Help: http://www.pirate4x4.com/forum/showt...ferrerid=89727 --Proportioning Valve http://www.pirate4x4.com/forum/showt...ferrerid=89727 --Dave'z Offroad Performance Rear Disk Conversion kit: http://www.davezoffroadperformance.c...c.php?f=3&t=52 Steering Box Rebuilding: http://www.pirate4x4.com/forum/showt...ferrerid=89727 Power Steering Pump Rebuilding http://www.toy4x4.net/ps/index.htm Axle Info Axle info - Toyota Toyota Mini Truck Front Axle Identification 79-80 no gusset 81-83 short gusset (to u-bolts) 84-85 long gusset (past u-bolts) Stock Toyota front axle measurements for comparison: 55.5" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, SA Hubs 58.25" wide, 29" spring perch centers, '79-85 Toyota trucks and 4runners, IFS Hubs 63.5" wide, (set up for coil springs) 90-97 FJ80 and FZJ80 Landcruisers '86-95 IFS front end is about 58.5" wide '93-98 T100 IFS front end is about 65" wide Toyota Rear Axle Widths: 55" wide, '79-85 4wd trucks/4runners - 6 Lug 58" wide, '86-95 4wd trucks/4runners - 6 Lug 56" wide, '79-95 2wd Trucks - 5 Lug 60.75" wide, '95.5-up Tacomas/4runners 66.75" wide, '93-98 T100 trucks Identifying Toyota Third Members: http://home.4x4wire.com/erik/diffs/ Find your factory Gear Ratio using your VIN http://www.brian894x4.com/Gearratiosanddiffs.html More Differential Information: "LPH" (Long Pinion Head) vs "SPH" (Short Pinion Head). by Drew Persson http://www.pirate4x4.com/forum/showt...23#post1478223 Myth Settled: 8.4, V6, 4cyl, ALL 8" - by Brian Ellinger http://www.pirate4x4.com/forum/showt...hreadid=228681 Pluging ABS sensor hole in late model diffs http://www.pirate4x4.com/forum/showthread.php?t=587522 Toyota 4 pinoin 6 cylinder 8" diff (30 spline) http://www.4crawler.com/4x4/Images/Diff6cyl.jpg Toyota Land cruiser high pinion 8" diff (30 spline) http://www.4crawler.com/4x4/Images/DiffHP.jpg Toyota 4 pinion 6 cylinder 8" 3rd from a '96-00? 4Runner (30 spline) http://www.pirate4x4.com/forum/attac...&postid=436184 Differential Mounting Differences Between Different 3rd Members http://www.pirate4x4.com/forum/showt...52#post5331552 ID Toyota Mini Truck axles 79-80 no gusset 81-83 short gusset (to u-bolts) ![]() 84-85 long gusset (past u-bolts) Rebuilding Front Straight Axle: http://www.birfield.com/~morgan/tech/axle/ http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml http://www.lukemiller.org/toys/1985_...t_axle_FSM.pdf ![]() Rebuilding Aisin Manual Hubs: http://www.yotatech.com/f116/aisin-l...ferrerid=12218 Power Steering Cooler Recommendations http://www.tacomaterritory.com/forum...teering+cooler Suspension links Toyota Rear Springs up front (RUF) http://pirate4x4.com/forum/showthrea...&highlight=faq 63" Chevy Spring Conversions: http://pirate4x4.com/forum/showthrea...ight=chevy+faq Transfer Case Info Trail-Gears TC Videos: t-case: http://www.trail-gear.com/videos/toy-tcase.wmv Dual case: http://www.trail-gear.com/videos/toydualcase.wmv Transmission and other Transfer case info: http://www.4x4wire.com/toyota/faq/parts/ Marlin transmission info: http://marlincrawler.com/transmission/rebuilt-complete 4.7 gear install (Kiwi found something the pro's were not aware of )Quote:
Quote:
Rear Differential Breather Extension: http://www.yotatech.com/f129/rear-di...her-mod-75747/ TTORA FAQ and TOyota Knowledge Base LINK: http://www.ttora.com/wiki/index.php/Main_Page IH8Mud's Toyota TAQ: http://forum.ih8mud.com/79-95-toyota...questions.html YotaTech tech Write Ups Roger Browns AKA 4Crawlers info (some great stuff) he covers just about anything you can think of 4Runner: http://www.4crawler.com/4Runner.shtml Cheap Tricks: http://www.4crawler.com/4x4/CheapTri...#MODIFICATION$ Drive Shaft Info General DS info Building a Square Front Driveshaft
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 08-08-2009 at 07:49 PM. Reason: fixed, added some links |
#6 (permalink) | ||||||
WInch Info
Quote:
Quote:
WINCH LINE Quote:
Quote:
Quote:
Quote:
Recovery 101 LINK http://www.pirate4x4.com/tech/billav...ery/index.html Winches From Hell Test Comparison: cheap Vs expensive winchs in real world situations
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 05-01-2009 at 01:23 AM. Reason: added a link |
#7 (permalink) |
When I find good stuff, I print it so I have a copy.
But this makes it difficult to reproduce or keep digitally. I wish a forum thread could be cut and pasted onto a word doc. (I've tried unsuccessfully to do this, forums must do something different so you can't do this) THanks, Phil
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs. Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit, Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap http://www.cardomain.com/ride/3171939 |
#8 (permalink) |
Gear Calculators
Here are a couple of gear calculators that you can you to figure real world rpm's with assorted gears and tire sizes:
http://www.4lo.com/calc/gearratio.htm this one has a ton of optionss: http://www.grimmjeeper.com/gears.html
__________________
#9 (permalink) | ||||||
Alternator upgrades/Electrical info
Toyota Electrical 101
good source for electrical stuff: http://order.waytekwire.com Toyota High Output Alternator INfo http://www.ttora.com/forum/showthrea...eferrerid=8874 Wiring Chart (amps to gauge size) ![]() Cool Aux Fuse box kit; http://dogbytecomputer.com/blue-sea-...ative-bus.html 1981 Toyota Truck Wiring Diagram http://s119.photobucket.com/albums/o...ruck%20wiring/ 1st Gen ('81) Vacuum Diagrams: http://s119.photobucket.com/albums/o...acuum%20lines/ 22R(RE) alternator upgrades (borrowed from this thread http://pirate4x4.com/forum/showthread.php?t=587456) Quote:
Quote:
Quote:
Compliments of Elton: click to enlarge, than when open, click again to enlarge one more time
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 04-26-2009 at 01:42 AM. Reason: found some alternator stuff |
#10 (permalink) | |
Quote:
#11 (permalink) | |||
Brake Master Cylinder/Booster Upgrades
somethings I have been reading about the 1" MC (I have one to install too) is that the brakes will feel worse after the swap because the ratio is different unless you convert to a dual diaphram master cylinder (86-87 turbo truck or 88 V-6 4runner, T100's or something like that)
with the stock first gen booster and 1" MC the pedal may feel like it is stiffer and go closer to the floor. here is the MC thread I was reading: http://www.pirate4x4.com/forum/showthread.php?t=763888 Quote:
Quote:
http://home.4x4wire.com/erik/4runner/brakes/ http://www.pirate4x4.com/forum/showt...ferrerid=89727 Load Sensing Proportional Valve: LSPV --more to follow Removal: http://4x4spot.com/proportioning.htm http://www.off-road.com/trucks4x4/ar....jsp?id=186295 Rebuilding Brake Calipers (good detailed writeup) http://www.pirate4x4.com/forum/showthread.php?t=770289 Turbo/Dual Diaprahm Brake Booster Upgrade Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 05-22-2009 at 07:05 PM. |
#12 (permalink) |
think it has to do more capacity will disapate the heat faster, like a deep sump oil pan for the engine.
__________________
#13 (permalink) | |
1st gen cab on 2nd Gen Frame
Putting a 1st Gen Cab on a 2nd Gen Frame:borrowed this from Pirate:
Quote:
__________________
#14 (permalink) |
dang good job man. good info. im sure i will use some. although i will be separating from my 82 soon. i know ill miss it
__________________
1982 toyota pickup, so far... propane conversion, 4:88 gears, celica tranny, 2" shackle lift, 1" body, and 5" leaf springs, u-bolt flip, crossover steering, 14" shock towers with Bilstein 5150 series shocks, costom built bumpers, 4runner bucket seats, 33x12.5-15 firestones, i got 4 low, i'm good to go! Pvt Peck, U.S. Army |
#15 (permalink) |
Putting Bigger Japanese Engines in Toyota Trucks
New website for putting Bigger Japanese engines in Toyota Trucks:
UZSWAP.com
__________________
#16 (permalink) |
1st Gen Truck Build Links
If you see a killer first Gen Truck build (2wd or 4WD) Send me a PM with the Link and I will add it here:
One of my Favorites: MT-Toy's '82 ![]() Slacker's 3.4 Super Charged Trekker ![]() Nitteberg's 1st Gen on Volvo Portal Axles ![]() Sweet 1st Gen Double Cab from Australia I want this truck!!! ![]()
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 05-14-2009 at 06:43 PM. |
#17 (permalink) | ||
Engine Info
22R Carb Trouble Shooting
http://www.bluebassdesign.com/boonin/carb_faq/ Converting 22R to 22RE info: http://www.pirate4x4.com/forum/showt...ferrerid=89727 Pre '83 EFI Conversion Link 22RE.com engine builder: http://www.engnbldr.com/ 22R(RE) Oil Pans: Quote:
22R(e) Propane Conversion kits: http://www.gotpropane.com/ ebay Kits: http://stores.ebay.com/Nash-Lift-Truck http://pirate4x4.com/forum/showthrea...=turbo+propane http://pirate4x4.com/forum/showthrea...=turbo+propane http://www.blackflag4x4.com/Unclejesse.htm http://pirate4x4.com/forum/showthrea...=turbo+propane http://pirate4x4.com/forum/showthrea...=turbo+propane 22RTE (turbo) http://www.22rte-trucks.com/simplema...orum/index.php Supra 6 cyl mods: (from this thread on Pirate) Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 04-03-2009 at 09:22 PM. Reason: more info |
#18 (permalink) |
Parts Sources
Fiberglass Fenders/Beds
http://toyotafiberglass.com/ Parts/Bumpers/Mounts Wab-Fab: http://www.wabfab.org/ High Lift slider adapter and other cool stuff 4Crawler Off Road: http://4crawler.com/4x4/ForSale/ProductLine.shtml Custom body lifts, Driveshaft spacers, electrical solutions Addicted Off Road: http://addictedoffroad.com/ TRD PARTS 4 U: http://trdparts4u.com/ 4xinnovations: http://4xinnovations.com/ Marlin Crawler: http://marlincrawler.com/ trail-gear: http://www.trail-gear.com/ All Pro Off Road: http://www.allprooffroad.com/ Downey Off Road: http://www.downeyoff-road.com/ now out of business Dave' Off Road Performance: http://www.davezoffroadperformance.com/ Tube doors, third members, driveshafts,etc Toyota Truck Dismantlers: body parts/axles etc The Toy Man (newberg, OR) http://www.thetoyotaman.com/ MazToy (troutdale, OR)http://maztoy.com/ Davez Off Road: http://www.davezoffroadperformance.com/ Yotayard (colorado) http://www.yotayard.com/home.htm Jim's Got Parts (Denver, CO) http://jimsgotparts.com/ California Mini Trucks (Cali) http://www.calminitruck.com/ NIX99 (washington state) http://nix99.com/ Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/ ToyoKings (FLA) http://www.toyokingsusedparts.com/ Yotatech Classifields :http://www.yotatech.com/f91/ TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3 Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4 Parts Locators: http://www.autopartslocator.com/ http://www.seekautoparts.com/ Sticker Kits Jame Dean Creations: http://jamesdeancreations.com/ Toyota vehicle sticker reproductions
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 08-24-2009 at 04:09 PM. Reason: added links |
#19 (permalink) | ||
SUspension
63" Chevy rear spring Conversion FAQ
Toyota Rears Up Front (RUF) FAQ Front Spring Hanger Placement: (when using longer than stock springs like Trail Gears) Quote:
Quote:
__________________
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 03-26-2009 at 06:49 AM. Reason: found some cool info |
#20 (permalink) |
Upper transmission bolt access mod
__________________
#21 (permalink) | |
Junkyard Bump Stop Alternatives
Found this and thought that it was well worth passing on:
Quote:
__________________
#22 (permalink) | |
Paint/Body info
Phildefino sent this to me, great info:
Quote:
__________________
#23 (permalink) |
Super Moderator-Sponsoring Member
Staff
Stickified.
![]() Too much good crap here not to get noticed.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. |
#24 (permalink) |
Pitman Arm Puller Repair
thought this was a good fix since a ton of my junk comes from Harbor Freight:
(I also like the high lift jack as a place to work on the steering box, easier than on the frame )
__________________
#25 (permalink) | ||||
AfterMarket seat bracket installs
This comes from a Master call Crash over on Pirate;
some of the brackets I have seen for mounting aftermarket seats...he did a great job. original thread: http://pirate4x4.com/forum/showthread.php?t=772248 much better than some of the crap I have seen done to mount seats (my own work included) Quote:
Quote:
Quote:
Quote:
Early 90's Acura Integra and Honda Civic seats work great in a 1st Gen truck. ![]() These things are great, there is a second hole about 1.25" over from the stock front outside mounting hole that lined up just about right, enlarged it just a hair and was able to use the inside front stock mount: ![]() just had to cut off about the lower .25" or so of the stock bracket to allow it to sit flat on the floor. I think that being able to use the stock front holes makes the install much more stable and install went very fast... outside rear mount came up with something similar to WSUWeston's brackets: ![]()
__________________
| Tags |
| 22re, alternator, heat, ig, internally, mod, notebook, pipe, pirate, regulated, signal, tach, toyota, truck, weird, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| parental units. any good ideas for me? | dijlop | Off Topic Talk | 63 | 06-12-2007 10:19 AM |
| ideas for bike racks - good or bad | 4biker | Newbie Tech Section | 13 | 06-09-2007 08:38 PM |
| possible mods and ideas to FJ | airrikk17 | FJ Cruiser | 1 | 04-29-2006 08:42 PM |
| good mods for the 2.7 liter | tacoma007007 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-09-2005 06:14 PM |
| Floor mat dilema any good ideas? | UKMyers | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-09-2002 09:14 PM |
