Sign in using an external account
| Pre 84 Trucks 1st gen pickups |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#151 (permalink) | |||||
Personal
Sales Rating: (0)
[OP]
__________________
82 dlx 4x4 22r 4 speed long bed 81 base 4x4 22r 4 speed flat bed 93 toyota pickup ext cab 2wd 3vz auto |
#152 (permalink) |
Personal
Sales Rating: (0)
[OP]
the regulator seems to be working just fine with key on key off test.
autozone load tested my charging system,there telling my my reg is bad. but my alt still makes no voltage. i was understanding the reg brings the voltage of the alt down to a controlled 13-14 volts. i have a old nissan alt that i use on my home made gen/welder. the nissan alt has to be excited to start,once started it puts out 70 volts dc at about 1k rpm.it doesnt have a built in reg. so i ordered a new reg,got a new alternator. if i install the new alt,would a dammaged reg ruin my alt? or should i wait till the reg comes in? The service manual reccomends to change out the reg and alt at the same time.
__________________
82 dlx 4x4 22r 4 speed long bed 81 base 4x4 22r 4 speed flat bed 93 toyota pickup ext cab 2wd 3vz auto Last edited by igotit; 02-03-2012 at 12:56 PM. |
#153 (permalink) |
Personal
Sales Rating: (0)
[OP]
something strange going on!
no oil on my dipstick! when i put the engine....she was full of oil,i double checked it! today i pull the stick....nothing. didnt find any leaks,engine doesnt smoke....wtf? i must have a bad leak,or bad eyes.
__________________
#154 (permalink) |
Personal
Sales Rating: (0)
new/clean oil can fool ya .. I'm sure you know that though !!
__________________
http://www.toyotafiberglass.com 86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE CURRENT PROJECT 83 Trekker SR5 DONE June 2011 My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#155 (permalink) |
Personal
Sales Rating: (0)
[OP]
its clearly not on the stick,ive check that the stick was going in all the way....ect.,i found 1 potienial leak.looks like i never tightened the upper alternator bracket bolt.
this bolt allows the bracket to piviot,which helps during alt install. tomorrow ill service the oil/filter again,wash the engine and see if that was my issue. but i have no oil in my driveway....unless it only leaked while driving. also have planned to adjust the valves,maybe free up that choke,install voltage regulator and hope that solves my issues. today i crawled under the truck for inspection,greese everything. i found slop in my front case side u joint,and slop in the rear. basically up and down movement....maybe 0.20 ths at most....enough for concern. ill try to do fluid change in my case,tranny,diffs next week.
__________________
82 dlx 4x4 22r 4 speed long bed 81 base 4x4 22r 4 speed flat bed 93 toyota pickup ext cab 2wd 3vz auto Last edited by igotit; 02-05-2012 at 03:25 PM. |
#156 (permalink) |
Personal
Sales Rating: (0)
you may would to do a one wire GM alternator swap.
also I would put in a disconnect switch, so the battery in connected to the truck when not in use
__________________
New ****1989 4runner SR5 stock 22RE*** http://www.yotatech.com/f199/rmp8080...uildup-250614/ 1987 Toyota Pickup. 1 1/2 inch body and 6 " lift, Bobed Bed 35 12.50 15's ***Coming Soon 4.3 V6*** Backup vehicle.... F-350 4X4 DRW super duty crew cab. Diesel 17 mpg. Daily driver 2000 VW Jetta TDI @ 47 MPG 333,000 miles My Build UpThread http://www.yotatech.com/f199/rmp8080...thread-243404/ |
#157 (permalink) |
Personal
Sales Rating: (0)
[OP]
i plan on the 1 wire install later one,get rid of this weak 50 amp.
right now my goal is put he back as my dd. it cost my $106 for the alt and reg....coulda done the gm route for that price.
__________________
#158 (permalink) |
Personal
Sales Rating: (0)
[OP]
New alternator and reg, still no volts.
I got hot supplied to alt and regulator. Guess its wire time. im getting really aggrevated,quickly. is there a know fuseable ling in the charging circuit? my alt is putting out 0.75 volts,the white hot is sending 12 to the alt,the harness for the reh is 5 wires,4 wires show 12 volts going into the reg.....still no charge. wtf?
__________________
82 dlx 4x4 22r 4 speed long bed 81 base 4x4 22r 4 speed flat bed 93 toyota pickup ext cab 2wd 3vz auto Last edited by igotit; 02-06-2012 at 12:21 PM. |
#159 (permalink) |
Personal
Sales Rating: (0)
I don't see a fusible link in the circuit, other than the one coming from the battery (white wire) to terminal B on the alternator. Sounds like a continuity tests is needed from the battery thru the alternator to the regulator, checking for corroded connections at each terminal. JMHO
#160 (permalink) |
Personal
Sales Rating: (0)
Maybe a short some where?
__________________
#161 (permalink) |
Personal
Sales Rating: (0)
[OP]
thats what im thinking too.
i found a short disscussion on a guy with an 82 that had the exact problem im having. he went through the entire harness,new alt and reg....found nothing. his last post was in 03.....never stated the problem.
__________________
#162 (permalink) |
Personal
Sales Rating: (0)
Start by placing a amp meter between the positive post on the battery and the cable. See if any current is flowing do it with the truck on. If you are drawing a lot of current then start removing one fuse at a time until no current is flowing. Shorts in the electrical system are very hard to nail down. Just keep disconnecting until the alternator puts out voltage. I wish I could be more help, but this is something of a pain.
__________________
#163 (permalink) |
Personal
Sales Rating: (0)
hey man good work with the swap, i just picked up an 82 long bed for 750 in running condition, the bed is toast though!
__________________
1987 toyota shortbed, 22r 5spd sittin on 31 bfg A/Ts . 261 rv cam -sold like an idiot 1982 toyota longbed, 22r 5spd, 5in springs, -sold 1986 toyota long bed, SAS, 22re, 5 spd, 5in springs, 5.29s. detroits front and rear, 36in tsl swampers, mile marker 12k winch on the front for ur sticky stuff! "anything you can do my toyota can do a WHOLE lot better........" |
#164 (permalink) |
Personal
Sales Rating: (0)
Any luck on the electrical problems?
__________________
#165 (permalink) |
Personal
Sales Rating: (0)
[OP]
been at work for 2 weeks,2 more weeks to go.
i was thinking about it today,what could be wrong,what can i do ect,wondering if a gm single wire will cure it....ect. sofar...heres my problem list. no charging sticking choke
__________________
| Tags |
| 81, antifreeze, car, cover, dlx, dry, gaskets, head, insurance, intake, marsh, rot, speed, standard, toyota, valve, yotatech |
