Pre 84 Trucks 1st gen pickups
Motor swap
Old 12-31-2006, 01:43 PM
yotaman17's Avatar
Motor swap
What would you have to change in an 1980 toyota pickup with the 20r and the 4spd to switch it to a EFi22r and 5spd?
Old 12-31-2006, 05:34 PM
myyota's Avatar
You would need the computer and wiring harness for the EFI to make it all work.
Old 01-01-2007, 01:25 PM
yotaman17's Avatar
that is what i was thinking but thought i would ask anywyas.
Old 01-07-2007, 06:39 PM
Aaronb's Avatar
You will also need the throttle cable, fuel tank, fuel line (supply).
Old 01-07-2007, 08:46 PM
toy283's Avatar
In lieu of a different fuel tank and internal pump, you could use the external pump available in some Toyota cars (my '84 Camry had one) and keep the stock tank. Just be sure to mount the pump as low as possible.
Old 01-08-2007, 05:27 AM
yotaman17's Avatar
could you run a 22r off propane? how would you do this?
Old 01-08-2007, 05:11 PM
Aaronb's Avatar
Yeah, lots of people do it. But its not street leagle. Not in California anyways, I dont know what the laws are in Washington.
http://www.gotpropane.com/
Old 01-09-2007, 05:55 AM
Angus1's Avatar
I'm getting ready to yank my 3.0 for a 22r on propane. Its gonna be cool. I'm not using the got propane kit Its way to much money.
Old 01-15-2007, 06:14 AM
fourwd1's Avatar
You'll also need to relocate the t-case x-member as the newer trannys are about 2" longer.
Gotpropane has all you need to run a 22R on propane.
Flying91
45
04-11-2024 04:39 PM
keithporter83
07-24-2015 07:37 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
msane99
07-17-2015 10:13 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Motor swap
