Looking for a 1982 22r head
Anybody use these guys? - http://www.yotashop.com/1982-toyota-...XPgaAkHS8P8HAQ
These are hard to find.
I was looking at these, but if you look at the website it doesn't include one for a 82. I've been planning on a long read and research one these engines, but the one I have now if running and I have so many other things that need to be done , brakes , running light , windshield leak , rust , radio , dash lights , Ac , defrost vents, dash pad , small leaks on axles. The more I think about it, I need to abduct a half dozen mechanics.
http://www.lceperformance.com/Street...-p/1021021.htm
oh and a exhaust leak , I'm going to be get their headers , from what I read I should enjoy just the sound of the truck enough to make it a good purchase
you would need one built pre mid year 1984 I believe. Deck height changed after that, so the ones mass produced now will not fit 1st generation 22r's. a 20R head will work also but the intake has round ports instead of square ones. also make sure it is drilled for power steering brackets and has the opening for mechanical fuel pump if that's how you are setup. I think the fuel pump opening would only be an issue on a 20r head. that first one on the rockauto search 13swords posted looks right. their return policy is usually pretty lax too.
cars-guy
66
01-26-2019 08:38 PM
RV8guy
21
10-02-2017 07:04 AM
Hallam Cook
06-02-2016 12:00 PM
tomboarderns
05-15-2016 10:13 AM
