| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How to get some power from 80 20R
__________________
83 Yota in progress,4.3 Chevy Vortec,700r4,33" TSLs |
#2 (permalink) |
port and polish the head, throw on a header, throw on an electric fan, get a weber carb for it. The truth is these motors dont make much HP even when you throw a ton of money at em.
__________________
Lift it, cause fat chicks can't jump... |
#3 (permalink) |
Swap in a V6
__________________
1981 Shortbed 4x4 Buick 231 V6, Turbo 350 4" springs 35x12.50 15 Bfg MT 300,000+ miles |
#4 (permalink) |
or just put a 22r block (81-84 only) under the 20R head .. hybrid engine . I have done it many times
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#5 (permalink) |
Do this at your own risk.
You can advance the base timing to about 14 degrees from 8 degrees. Open up that spark plug gap a little too... Also heard good things about going with a Mallory distributor. A solid tune up will help and is not risky at all. I noticed a minor performance increase with the addition of a Mr. Gasket universal air cleaner. Maybe that was psychological... If you have a catylytic converter (I think CA trucks had them in this year) you could cut it out or replace it with a high flow cat. Remove the smog pump. This cuts parasitic drag on your engine. It is very easy to remove but watch the air injection on the exhaust as you will probably have to block it off. You may experience backfiring without the air injection (I doubt it though). Removal of A/C and power steering pump (if so equipped) can also result in a performance boost. Removing your power steering pump isn't a good idea unless you have a plan to convert it over the manual steering... I think those are the "Economical" things you can do for your engine. For more performance ideas you should be thinking serious machine work as any old 20R out there in stock form is probably hanging its head with age (as mine is). Maybe a bolt on header or a mild cam but honestly those kinds of things are expensive and not worth the performance gain on a tired old engine that has probably never been rebuilt... That's my opinion of course - your mileage my vary. Overall you'd be surprised at how rapidly you can move around town in an old stock 20R with just a good tune up. |
#6 (permalink) |
cam, header, upgraded air cleaner, weber carb, tune-up, and some gears
__________________
87 Toyota 4Runner 22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time... 79 Toyota Longbed 4x4 Frame-off Resto time. 04 GMC Sierra 1500 the DD |
#7 (permalink) | |
Quote:
these engines aren't known for making any horsepower without lots of head work and high compression pistons. Gears will give you the biggest noticable improvement.
__________________
| Tags |
| 20r, hp, motor, power, truck, weber |
