Pre 84 Trucks 1st gen pickups
High Steer question
Old 11-26-2007, 07:57 PM
Island_Yota's Avatar
High Steer question
My front axle is in the stock location, im running 4" lift springs.. do I need a drop pitman arm or a flat one, I bought an IFS box that didn't come with one, but hey, atleast it saves me taking one off! Im buying the heavy duty box mount aswell from trail gear, Im presuming it comes with instructions but where do I mount it if im running stock axle location? Obviously somewhere that the tie rods dont make contact.
Old 11-27-2007, 05:24 AM
Fossilized
Staff
dropzone's Avatar
Trail Gear IFS mounts comes with NO instructions...I am still trying to find a good write up that says something besides mount it as 'far forward as you can and so it doesn't interfere with the tie rods" On the TG forum they said they would post some instructions. Guess I need to check Pirate and Marlin too
Pitman arm: I bought my trail gear high steer kit with the dropped pitman arm but am hoping they will let me swap it for the flat pitman arm. The Flat one is what everyone around here says to use to get good clearance...
Old 11-27-2007, 06:02 AM
waskillywabbit's Avatar
I have my steering off completely to convert to full hydro so I will take a pic of the mount on my frame to give you a better idea if you like.
Old 11-27-2007, 09:50 AM
Thanks for the replies I contacted Trail gear and they advised I use the Drop Pitman and if it doesn't work out just send it back and they will swap it for a flat.
Old 11-27-2007, 09:54 AM
mrtejman's Avatar
I used the drop pitman arm from trail gear, but my steering arm was hitting my leaf springs with 9 degree axle shims. It works fine without the shims though. Mount the steering box so that it is touching the body at the front of the truck, as far forward as possible. I used the stock hole that was farthest back for my new box and drilled the front hole out.
kazuya2416
04-05-2024 02:17 AM
glowz825
01-25-2022 09:28 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Quick Reply: High Steer question
