help!!79 4wd w/9mm drive shaft flange holes!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-08-2009, 05:07 PM   #1 (permalink)
i have a weird request but if anyone here can help i would greatly appreciate it. I have a 1979 toyota pickup 4x4 that has the rare but crappy 9mm drive shaft flange holes... the problem is that woever worked on the truck before i bought it lost 4 of the bolts and now i cant find them in any dealer. if anyone has them and is willing to ship them im willing to buy them... thanks all
erickalfaro is offline
Old 10-08-2009, 05:48 PM   #2 (permalink)
slacker's Avatar
I have re drilled the flanges to fit new bolts before .. very easy to do .. just make sure you use a very hi grade bolt .. grade 11 is factory .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 10-09-2009, 06:38 AM   #3 (permalink)
83
83's Avatar
Marlin Crawler (and probably other places too) sells a flange that ought to bolt to your truck with a bunch of holes for all different bolt patterns. I wonder though if your drive shaft would need the holes opened up a bit too.. http://www.marlincrawler.com/differe...rential-flange
I just put in a later model rear diff and the bolt pattern was different, so I just drilled new holes. Was a real pain...since I didn't take the flange off the differential and don't really have a way to clamp it to a bench, and I went through 3 batteries in my drill...but it worked.
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 10-09-2009, 09:35 AM   #4 (permalink)
4Crawler's Avatar
Yes, either drill out the holes or I recall a buddy of mine used to use 3/8".Grade 8 bolts on his '83 when he lost a few bolts.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-09-2009, 10:28 AM   #5 (permalink)
I would just go down to your local fastener store and buy new bolts, just make sure they are hgh grade factory is 11 like said above
LowSantorin is offline
Old 10-09-2009, 10:33 AM   #6 (permalink)
4Crawler's Avatar
Probably have a hard time finding 9mm metric bolts, that is a very uncommon size.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-13-2009, 09:30 AM   #7 (permalink)
10mm bolts
drill them to 10mm and order some from any dealer or marlin has them, about $40, altho u can use regular bolts
the factory bolts are sholder bolts that go through the yoke and flange there by centering them together. a better way to go if ur looking for a long term fix.
interested2meet is offline
Tags
10, 44, 9mm, bolt, drive, flange, flanges, holes, metric, mm, pattern, shaft, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
