| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Has anyone ever broke the crossmember
#2 (permalink) |
Yep, I stripped one out when installing the BudBuilt cross member. You could go to most any 4x4 shop that does welding (or an welding shop really) and get them fix it. I looked into it but it was like 200 bucks and I said no thanks. So, I am one bolt shy. How many did you say you stripped?
__________________
1989 Truck, Regular Cab, 3.slow, 5-speed, 32s, 4.10s, Trail Gear rock rails, Bud Built full belly skids & E-Locker Mod. |
#3 (permalink) |
2 inside on same side
#4 (permalink) |
do whatever work you need done. bolt it up. have a shop 'tack weld' in 2 spots.
If you need to take it off again use a crow bar and break the tackwelds. They'll hold better than bolts, but you can snap it back off if needed? I've done that on my other trucks before. p.s. if you can't crowbar the cross beam off, use a grinder and just grind down the tack welds, you're going to do this before you remount the crossmember again anyways. |
#5 (permalink) |
mine are broken off as well...both on the passenger side. i only have 2 bolts holding. i was going to have a plate welded on the inside of the frame rail to look like the outside and use some nuts and bolts. haven't done it yet. spot weld would be the easiest.
__________________
81 4WD Flat Bed |
#6 (permalink) |
EVERY frame I have worked on , has the same issues ..
what I did was, first cut the head off the bolt , and freeing the crossmember to get it out of the way .. Then you can easily use a magnet to get the old one out from one of the "jig" holes . I then found some grade 9 bolts and nuts that would work in place of the stock ones .. through the same hole I removed the old rusted nut and bolt , I made a SST , out of 16G to hold the new bolt and lock washer in place while I tightened the new bolt into place . Nothing fancy , just something to hold it untill the lock washer can start to do it's job . it was fairly easy .. you just need to think about it for a second ! .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
| Tags |
| budbuilt, crossmember, install, rear |
