| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
failing emessions, need advice.
__________________
81 Toyota pickup 22r, 5spd, 4x4, longbed on 33's... custom suspension in the works. 79 Cherokee Chief Widetrack "Kronk" TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion... 91 Chevy K1500 - The Hauler TBI350, built 700r4, NP241, awaiting 4" lift... 90 XJ - 5.5" lift, 33's, bushwhacker cutouts, sliders, bumpers, winch... 08 Mazda CX9 - Zoom-Zoom! |
#2 (permalink) |
Valves Adjusted?
Other than that, i'd look to cat and EGR as well.
__________________
The Daily Driver: 1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock The People-Hauler 1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock The Dump Runner 1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916 |
#3 (permalink) |
FSM has proceedures for checking the EGR. I can scan & post if you want..
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#4 (permalink) |
Have you considered o2 sensors.. they can be making it run rich or leaning it out depending on how they are reading. Might be a cheaper option than going with EGR and CAT. O2 are around 40 vs 70-90 on universal Cat thats cost on parts maybe alittle higher depending on where you go. On testing the EGR you can apply vaccum to it to see if it holds.. thats how we test them.
#5 (permalink) |
Our trucks don't have 02 sensors.
__________________
#6 (permalink) |
I would rule out the EGR as a cause for high amounts of hydrocarbon. EGR is designed to control Nox and not carbon. Sounds like you have a jetting issue or a non functioning cat or both. Has the carb had any modifications? Many of these trucks ran really lean at idle from the factory (especially Canadian or Cali spec) and people rejetted them to make them run smoother. Pull the carb and clean it. Make sure your choke linkage is working properly as this will cause a rich mixture for sure. Check the jet sizes and low speed air screw settings.
My 84 22r past the emission every year I needed it to. Somtimes I retard the timming a couple of degrees from stock before the test just for some extra insurance as well. This helps mostly with the NOX reading though. |
#7 (permalink) |
Fair enough lol, Ive only been a yota owner for about 2 weeks.. wasnt sure when they started puttin o2s on vehicles prolli atleast has to be fuel injected otherwise the o2 wouldnt do much anyway.
#8 (permalink) |
the carb is new from what i understand. one of the PO's had a problem with bad carbs (kept letting the same idiot rebuild it) and when he sold it to the next guy he put a new carb on it (or maybe remanned) and everything ran great since.
but IF the knuckle heads rebuilds were running horribly rich, i suppose it could have burned up the cat. Al
__________________
