| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Cooling issues!
#2 (permalink) |
Nothing huh???
Guess I will risk my ass on pirate! ![]()
#3 (permalink) |
Did you test the new thermostat on the stove or hot plate so you no for sure if its opening? When its cold my junk doesn't like to open often. You can drill a small by pass hole in the t-stat if its that concerning, just took longer to warm up, wasn't bad it TX summer but sucked in WA winter mornings.
How's the temp gauge looking? Welcome to YT
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784 |
#4 (permalink) |
Thanks Muddpigg!
Yeah the new t-stat is the OEM Toyota from the dealership. I tested it this AM after it failed to open last night. I ran a NO t-stat test again this afternoon and got perfect flow through the radiator. I think the propane vaporizer and the potential for air bubbles/steam under the t-stat is not allowing it to open. The "heater core lines" as I have NO heater anymore, now serving as propane vaporizer lines are getting F'ing hot with ANY t-stat in the housing in conjunction with the t-stat NOT opening! The "fellows" on Pirate think it is just not getting hot enough, so do I! I removed the jiggle valve so I also have a 1/16 hole in the flange, but last night that still did not work! I think my aftermarket temp guage is working OK but I am reluctant to keep allowing my motor to reach 250!!!!!!!!!!!!! I don't want to do a head gasket now. I plan to go on a short "Madien Trip" tomorrow with out the t-stat as I don't want to ruin the motor! Is it possible that the intake manifold is NOT allowing the t-stat to open. I am NOT running the stock "o-ring" as I think my housing is not original. There is NO way I could get the housing to seal with that o-ring without some other kind of gasket which none of the parts catalogs call for??? Later pete out to the shop to bleed the brakes......MUST WHEEL TOMORROW
#5 (permalink) |
It'll take forever to warm up with no t-stat and maybe to spring in cold weather. Is anything obstructing the t-stat from opening? I use gasket sealent on mine no issues.
__________________
#6 (permalink) | |
Quote:
That is what I am wondering, is the the manifold obstructing the t-stat??? I have never used anything but gasket sealent on mine either! Really frustrating..................TESTED, FUNCTIONING, t-stat in place, no flow in radiator, at least until the guage says 250+ and I am really getting worried, or.........................................NO t-stat and perfect flow in the radiator. SOB I will figure this out!
#7 (permalink) |
Park it on a hill to burp the system. Or drill a small hole in the t-stat.
__________________
#9 (permalink) |
Rock on.
__________________
