Choke not opening help!
I've done a resistance check on the choke coil , its all within specs... I then did a power test to see if it was receiving voltage, there is no voltage reading from the terminal.. I've checked all fuses in the dash, tested voltage with the engine running , and with only the ignition switch on.. Has anyone else had any similiar problems ? Could it be a fusible link somewhere ?
Thanks for your time
got mine at oreilly i think, autozone, carquest, napa; they all have them. its pretty simple set up, just get the line of pull with the least amt of bends and youll be ok.
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
PNW94Runner
09-29-2015 02:55 PM
Odin
09-26-2015 06:56 PM
