| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
83 22r low rpm stumble/misfire/surge/cutout/i don't know
__________________
QUIS CUSTODIET IPSOS CUSTODES? |
#2 (permalink) |
Timing? It was off on my jeep and causing similar symptoms
__________________
The Daily Driver: 1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock The People-Hauler 1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock The Dump Runner 1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916 |
#3 (permalink) |
try your egr valve. if its still there. that fixed the same problem on my turck
#4 (permalink) |
22r
I am going to check the timing tomorrow. there is no emissions related equipment on the truck anymore.
thanks for the advice
__________________
#5 (permalink) |
I had a similar problem on my '83 22R and needed to adjust the idle mixture and idle speed screws. I didn't have a tachometer but rather set the idle mixture screw to factory (4 turns from fully closed), then adjusted idle speed until it didn't stutter.
Follow the guide on this website: http://www.bluebassdesign.com/boonin/carb_faq/ Of course, I did all this after rebuilding my carburetor. But I think it was the idle screws that finally fixed the problem, should have tried them first.
__________________
1983 2WD Longbed Pickup Last edited by Jeff D; 10-03-2009 at 10:09 AM. |
#6 (permalink) |
Thank you for the advice. The problem ended up being a combo of timing adjustment and idle adjustment. before i was adjusting each setting individually. when i finally got the timing light i adjusted the carb and timing at the same time and that really helped. the truck is running great now.
__________________
| Tags |
| 1982, 22r, 95, 99, adjust, grand, idle, low, misfiring, pickup, prix, rpm, sr5, stumblemissfire, surges, tacoma, toyota |
