82 pickup radiator question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-11-2009, 07:02 PM   #1 (permalink)
I have an 82 with a 2.4l 22r 2wd.I am swapping out radiators due to a bad leak and I'm wondering what the second smaller pipe goes to which is connected to the lower spout on the radiator. There is a hose that connects to it and leads into the firewall can someone tell me what it is?
-Yoda- is offline
Old 10-11-2009, 07:11 PM   #2 (permalink)
kdo58's Avatar
Send a message via Skype™ to kdo58
heater
__________________
1981, 22r, comp cam 280, weber 38, stage 1 porting,31" toyo mud.
kdo58 is offline
Old 10-11-2009, 10:52 PM   #3 (permalink)
I bought the car from my girlfriends dad and he bought the radiator and gave it to me with it...the thing is it's for a 4wd so it doesn't have the smaller pipe on the spout for that heater tube.....can I just block the tube off and not worry about it?
-Yoda- is offline
Old 10-12-2009, 10:30 AM   #4 (permalink)
Anybody?
-Yoda- is offline
Old 10-18-2009, 02:21 PM   #5 (permalink)
monstertruckman's Avatar
if its in the bottom corner then i think it will be a drain pipe
__________________
mk1(82) with 89 2.4d,bobed 18 inches,full soft top,9 inch lift,full exo cage,swing out tyre carrier,front tubular winchbumper with x9,rock sliders,rear tube bumper,5 speed box,front truetrac,rear arb lockers,twin transfer case,4.7 crawler gears,38 inch super swampers,rear disc brake conversion,transmission disc parking brake,5.29 ring& pinnions,snorkel,air compressor,cb,twin batteries,low profile gearbox mount,diff guards,twin sticks
monstertruckman is offline
Old 10-18-2009, 05:34 PM   #6 (permalink)
suncomb1's Avatar
The heater pipe connection on a 4x4 is not on the radiator. There is a small pipe that is connected to the center of the cylinder head on the passenger side-Feed to the heater control valve. There is a large pipe with a small inlet pipe on the driver's side. The lower radiator hose connects to the large pipe with the small inlet pipe, then a second radiator hose connects from this same large pipe with the small inlet pipe to the water pump inlet. The return heater hose from the firewall is connected to the small inlet pipe on the large pipe. The only connection for a small hose on the radiator is the overflow bottle hose connection located on the fill neck.
suncomb1 is offline
Old 10-18-2009, 05:50 PM   #7 (permalink)
slacker's Avatar
ATM cooler
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 11-02-2009, 09:36 PM   #8 (permalink)
1stgenboy's Avatar
turbo models have a hose barb coming off the top towards the drivers side...
1stgenboy is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
