| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
82 4x4 front wheels not engaging
#2 (permalink) |
welcome to YT. you can test your front driveshaft but twisting both ends...it would be pretty obvious if your DS was fubar.
Which front wheel is not engaging? I am thinking your buddy meant to say that the splines in the hub are not engaging. Could be a busted hub ring.
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#3 (permalink) |
i'd bet on a busted hub. got some used warn ones that should fit that.
#4 (permalink) |
or ya could just rebuild yours....its SUPER easy..you take it apart....clean everything..put everything back together with some greese from the rebuild kit..and then install new gaskets...BANGO! problem solved...
or ya could just get some WARN hubs (brand new) from autozone or oreiley's..
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#5 (permalink) |
he was thinking the splines were wore out in the front drive shaft, but the shaft was spinning when the wheels were rolling. i went to put it up on my trailer. with my other rig, i put the front wheels on the trailer, and use 4 wheel to walk up on. this one, the rear tires were spinning in the grass, and the fronts weren't moving
#6 (permalink) | |
Quote:
#7 (permalink) |
uhh.......good?..do i know you..LMFAO..just wonderin man..lol
it's runnin good..but i just nee to fine tune the carb a little now..LOL
__________________
