YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-09-2008, 01:43 PM   #1 (permalink)
79 Toyota pickup- lift spring ideas.
Hello,
I just bought a 79 pickup, 4x4. it's stock right now, but the guy i got it off had 6" lift springs in the Bed. This is more lift than i want. Are there any issues With taking a leaf out of the pack to soften and slightly lower the springs?
thanks,
Dan
__________________
Hello, I'm Dan
just bought- 1979 yota pickup, stock so far.
2001 Toyota tacoma, xtra cab, manual trans, TRD package... Totaled 9/22/07, miss it every day...
1996 Ford F250 powerstroke.
secondarychaos is offline
Sponsored Links
To remove this ad, register today!
Old 10-09-2008, 02:05 PM   #2 (permalink)
nico's Avatar
Play around with the spring packs all you want. Be aware, however, that the amount of arch in the springs is the primary reason that there's so much lift. Taking out leaves will soften the springs, but won't drop the lift too much.
__________________
1981 4WD SR5 Longbed - 22R - L52 - 4.88's - Detroits - 3" Downey springs - MV-12's - 34" LTB's
nico is offline
Old 10-09-2008, 02:12 PM   #3 (permalink)
But if it softens it, wont it reduce how high it is when the weight is on it?
or am i smokin some good dope?
__________________
Hello, I'm Dan
Old 10-09-2008, 10:00 PM   #4 (permalink)
yukon6inchlift's Avatar
i took a leaf out of tg 3 inch lift springs once and they flattened out nice and did not wrap bad but got longer. this made a small issue with the shackle not being vertical. my friend tried that with 6 inch lifted springs with poor results, developed a bad wrap.
grass valley, ca hard to say what ur smokin!!!!
__________________
I dont care what u drive,,,long as u will wheel it!! lol
yukon6inchlift is offline
Old 10-09-2008, 10:20 PM   #5 (permalink)
algranger's Avatar
i would add in a leaf from a lower riding spring (maybe stock pack if possible) last time i pulled a leaf from a stack it got some nasty wrap and snapped right at the perch.
__________________
Hi-Tech Redneck
algranger is offline
Old 10-10-2008, 01:11 AM   #6 (permalink)
Al's Chop Shop's Avatar
Send a message via AIM to Al's Chop Shop
Quote:
you actually don't want a vertical shackle or your spring will have very little droop.
back to the original question... there is nothing wrong with mix and matching spring packs.
Al
__________________
81 Toyota pickup - Hers
22r, 5spd, 4x4, longbed on 33's... awaiting custom rears up front w/ downey shackles, chev 63's out back double shackled and 36's...
79 Jeep Cherokee Widetrack "Kronk" - The Build
TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion...
91 Chevy K1500 - The Hauler
TBI350, built 700r4, NP241, awaiting 4" lift...
92 FJ80 Land Cruiser - Fate undecided
Al's Chop Shop is offline
Old 10-10-2008, 06:22 AM   #7 (permalink)
Al
my shackles was almost laying flat...bottomed out if i hit a bump. missing links fixed me right up!!!
__________________
Old 10-10-2008, 08:39 AM   #8 (permalink)
I'll keep the wrap and shackles in mind. thanks guys.
yukon, sounds like you've been here? lol
__________________
Hello, I'm Dan
Old 10-10-2008, 03:20 PM   #9 (permalink)
Talking
yep, 6 inches of lift is quite a bit. you may have steering issues, driveline issues, shock issues, ect. its all connected. i'm no toy expert by any means but, changing 1 thing often times affects other things.
one more thing if ur looking to wheel that toy, flat springs work the best for articulation. big lifts are mostly for show, look at most crawler buggies, they are low with skids. center of gravity and what not.
__________________
Old 10-10-2008, 03:42 PM   #10 (permalink)
That's why i want to flatten them out some. I think 2-2.5" of lift would be good for tire/ground clearance, articulation and COG all together. maybe i'll try and trade someone for a shorter lift. I definately would like a little more tire room.
Yes, i hear you on steering, drivelines, shocks and brakes.
Steering- already planning on upgrading
Drivelines- hoping to do some square drivelines. Not going to be a DD, but most likely will drive to the trail.
Shocks- upgrades planned.
Brakes- i've lengthened brake lines before, i can do it again.
Thanks for all the help!
__________________
Hello, I'm Dan
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota Pickup Suspension Lift? RB Cam RB Offroad Tech 39 01-06-2008 09:08 PM
85 toyota pickup suspension lift question corvettelvr73 84-85 Trucks & 4Runners 8 05-09-2007 10:20 PM
Spring break ideas AndYota Off Topic Talk 11 02-21-2007 07:54 PM
89+ toyota pickup xtracab lift teamafx Items Wanted 1 11-23-2006 06:25 AM
HELP!! Need ideas where to take gf for Spring Break?? AznSky Off Topic Talk 8 01-25-2005 03:41 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
