| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
77 truck will only go in 4th
#2 (permalink) |
Try the slave cyl but it sounds to me like a few synconizers went "klunk"
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) |
#3 (permalink) |
I don't think its the syncro's. The reason is that the truck can be in first all the way and when you let the clutch out the gear grinds. It starts to grab and the truck will inch forward, but fully releasing the clutch pedal causes the grind. Would that be a syncro? I always thought the syncros would cause a grind when going from a gear to another gear, or am i wrong?
thanks DB |
#4 (permalink) |
Oh i see what your saying now..... yea your clutch may not be engaging all the way causing the syn to slip off the gear because its only grabbed like a pinch of it..... tiz possible..... if it flows into all the gears fine without jumping out your syncs should be fine. Yea try the slave cly and possible clutch master cyl..... clutch pedal out of adjustment.... try adjusting it a bit maybe....
__________________
