| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4in lift question?????
__________________
86 runner 22re carry bomb exhaust |
#2 (permalink) |
the stock steering will work for now, the only exception is that you might need a dropped draglink. WHen I first got my '81 it had a 4" lift with the stock steering. The draglink was stock, it sucked, swapped out to the dropped draglink--adjustable and that helped.
got rid of the stock push pull and went to High steer with a 94 IFS steering box...box better steering. SHocks--probably gonna ride rough...
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#3 (permalink) |
well..i believe you'll wanna get some new shocks...cuz your stock shocks aint gonna be long enough???
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#4 (permalink) |
thanks for the info all i have to give him is my bumper for the springs so i think its a good deal and yes thay are toyota springs
__________________
#5 (permalink) |
You will need the dropped drag link, a dropped torque arm, an extension bracket for the rear brake proportioning valve lever, possible extended front drive shaft due to spline engagement, longer front / rear shocks, heavier front sway bar, maybe a rear sway bar and wider tires / wheels for stability.
#6 (permalink) |
I run 5" springs with the drop drag link, and it works well enough. I don't run any extreme trails, just street and dirt trails. I didn't have to extend the drive shaft but I retained the sway bar and that really limits my axle drop. If you don't use the torque bar and the sway bar you can gain a lot of wheel travel, but the on road handling is sacrificed.
If I had it to do over again I would have saved the $100 on the drop link and put it towards the crossover steering. That’s the next thing I plan on doing once I get back home. Don't forget to post before and after pictures. |
