| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1980 4x4 heater mystery? (help)
__________________
1980 Toyota 4x4 22R with weber carb 3" lift L43 4 speed |
#2 (permalink) |
on my 1983 the heater valve is under the hood on the firewall. Between the brake master and valve cover.
Hope that helps
__________________
NEW*** 1985 lifted locked dual cases bumpers and sliders now my daily! 1985 Stock Had to do head gasket and some other minor things left. 1983 Hilux 4X4 SR5 4 Sale 3" Rough Country Lift 32" Goodyear Wranglers. Custom bumpers being made!! 1995 4Runner 4X4 V6 SR5*****TRADED |
#3 (permalink) |
Take a photo of your firewall from inside the engine compartment. In my truck, the valve stopped working, so a previous owner had rigged a valve...didn't connect to the heater control. Basically you open it for the winter when you want heat, close it in the summer when you don't. Someone may have taken the valve out, but it's also possible that it's stuck, or your heater core could be clogged.
Is it hard to move the hot/cold control? Are you saying it moves fine, and you can see the cable sticking out of the firewall in the engine compartment, not attached to anything? That's how mine is. Yours look anything like this?
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock Last edited by 83; 11-03-2009 at 02:13 PM. |
#4 (permalink) |
Wow. Am I in trouble now. The guy I bought the truck from put a new engine in. He stripped everything out of the engine compart ment... painted it and put in a new engine. There is no valve on the firewall anymore.. I can put on in but the blue cable is so short I cannot beleave it went outside the firewall though it may have. With no valve I should have lots of heat in the heater position. Is there another valve inside? I can see the heat/def lever operating all of the various doors and they are all working correctly. Could it be a pluged heat exchanger or is there and interior door I cant see.
Thanks for all of you help mark I am now pretty sure its plugged so I think I will gently use the garden hose. m
__________________
1980 Toyota 4x4 22R with weber carb 3" lift L43 4 speed Last edited by 69800; 11-08-2009 at 04:24 PM. Reason: addition |
#5 (permalink) |
that engine bay is perfect WOW
__________________
81 Toyota 4x4: 22R, weber carb, long tube header w/custom exhaust, L45 4 speed, 4.56 V6 3rds, TG highsteer, RUF w/sky shackle, custom rear springs w/shackle, 2" BL, 32x11.50x15 BFG MTs on 15x7s(street), 37x13.50x15 DC FC2s on 15x8s(trail), ARB air compressor, KC lights, topper... |
#6 (permalink) |
Thanks. the guy I got it from was really anal about it. Then he lost his job. I felt pretty bad that he had to sell after all of that passion
__________________
#7 (permalink) |
Yeah that's super nice and clean. I can't really see up close to the firewall in that photo, but it looks like coolant would be flowing right in with no restrictions (no valve), so you should have heat. Can't say for sure, but I would say you've either got a sticking thermostat (have you touched the heater core hoses going into the firewall when the engine is warmed up to see if they're hot?), or a clogged heater core, but you'll have to find out for sure. You can definitely try flushing the heater core.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#8 (permalink) |
Can you see in my photo on the far right side, partially under the hose, the wire with a loop on it sticking out? That's what would control the valve..
__________________
#9 (permalink) |
mystery heater fixed
I see where the blue cable goes now thanks. the guy had hooked up the heater hoses backward. I still dont know why the heat exchanger care which way the water goes but it does. I will try to find a valve I can hook the cable up to later.
thanks again
__________________
| Tags |
| 22r, heater, hook, ups |
