Pre 84 Trucks 1st gen pickups
1979 Truck 20R carb tuning help?
Old 07-16-2011, 01:46 PM
the big d's Avatar
I have looked but cannot find the factory specs for the idle air mixture screw, I know it is running rich, but how much I do not know. It was 5 turns out from closed.
Old 07-17-2011, 09:55 AM
the big d's Avatar
Is there a way to tune it?
Old 07-23-2011, 09:14 PM
Yota1979's Avatar
bring it to a shop and get a tune up, sounds like you wouldn't know where to start lol
Old 02-05-2012, 05:34 PM
the big d's Avatar
Truck is tuned up. new plugs, wires, cap rotor, air filter fuel filter... everything that I can think of that can affect tuning... I was getting around 15mpg, now about 12mpg. Driving is 60 highway/40city, driven aggressively for the little truck. Nothing rebuilt... any specs? I cannot find them anywhere.
Old 02-09-2012, 10:08 PM
ConSeann3ry's Avatar
lean it out until it idles highest, then make it a little richer
Old 02-10-2012, 05:49 AM
Lons81's Avatar
Usually, turn the idle mixture screw in until it just bottoms out, the unscrew about 2 1/2 to 3 1/2 turns. Start engine and set the idle speed to around 750-800 rpm. Adjust the mixture screw in/out 1/2 turn to get smooth idle. I usually bump the throttle after each adjustment checking for smooth acceleration off idle.
You can download the FSM here http://www.ncttora.com/fsm/ Scroll down to the 79-85 section. There's a lot of info in this PDF file. Carb adjust is in the fuel section
Old 02-10-2012, 10:11 AM
funcrazy1's Avatar
That is not very nice we are a helpful community my man
Would this be a stock carb or a weber carb or asia carb?
Old 02-10-2012, 12:11 PM
the big d's Avatar
The factory carb btw.
Old 02-10-2012, 12:35 PM
nightstalker's Avatar
5 turns out sounds extremly rich, any mods? i expect your plugs were looking black, most carbs, you will bottom out the air mixture screw(s) then start at 1 1/2 turns out, if doing by ear, i would do what was mentioned above by lons81. jmo
Old 02-10-2012, 03:41 PM
the big d's Avatar
Stock engine, 360k or 460k miles. (Uncle can't remember how many times it rolled over)
bigblue82
10
07-06-2015 08:27 AM
kazuya2416
06-27-2015 12:24 PM
dirtrider0129
10
06-24-2015 12:24 PM
paxanders
06-21-2015 06:29 AM
94 First Responder
06-06-2002 02:19 PM
Quick Reply: 1979 Truck 20R carb tuning help?
