Rear differential Swap? Step by step? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Axles - Suspensions - Tires - Wheels
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-21-2009, 12:00 PM   #1 (permalink)
BeNoC's Avatar
My rear diff sounds like its about to go, the pinion seal and bearing are shot and i think i waited way to long to fix them. The rear end whines so loud, im surprised it hasn't locked up yet. Yes i check the oil and keep it to the level it should be at.
I was wondering how hard it would be to get a complete diff and swap it back into my truck. Is it really that much work? Anyone have a step by step guide.?
I have a 1990 xtracab 3.0 5 speed, i think the gear ratio is 4:10 but id like to hear it from a couple more people to be sure.
Thanks
__________________
-1990 Pickup V6 / Herculiner Roll-on Bed Liner
-2x 12" audiobahn 800 watt subs with Pioneer 800 watt amp.
BeNoC is offline
Old 10-21-2009, 12:28 PM   #2 (permalink)
raydouble's Avatar
http://www.brian894x4.com/Gearratiosanddiffs.html
You have a 8" v6 3rd member, any 8" non-trd member will bolt in place.
http://home.4x4wire.com/erik/diffs/
http://www.ncttora.com/fsm/1993/suspensionandaxle.html
Disconnect rear brakes at wheel cylinder and ebrake cable, pull out both rear axles (4 nuts where axle flange meets rear hub), disconnect driveline, unbolt third member, pull out.
__________________
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front
bumper-custom 6 leaf rear
01' 4Runner SR5 4WD 5VZFE all stock
raydouble is offline
Old 10-21-2009, 12:31 PM   #3 (permalink)
raydouble's Avatar
Also searching the site and others can yield the answer most of the time.
__________________
Old 10-21-2009, 04:01 PM   #4 (permalink)
Murakami's Avatar
you're in the for sale section. try posting and searching in the main forum.
anyway, it's easy. just find another third from another truck or runner and bolt it in. depending on what size tires you're running you may want to try another ration as well such as 4.56s which go well with 31 inch tires.
__________________
93 Pickup, std. cab, 22re, 5 spd., 33x12.5 Mickey Thompsons on 15x10 AR Outlaws and 4.88s.
Murakami is offline
Tags
differential, front, rear, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
