IFS 4.88 diff (ADD) - PA - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Axles - Suspensions - Tires - Wheels
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-05-2009, 12:56 PM   #1 (permalink)
$150 + Shipping > 91 ADD front diff with stock 4.88 gearing
I've never wheeled this diff as it came out of a factory 4runner. I'm located in Central PA - shipping with be around 50 - 75 bucks I presume.
The ADD diffs are desirable because it has needle bearings on the passenger side axle shaft, non-ADD diffs don't have this. You can swap your current IFS long tube to this diff to eliminate the ADD system (I've done this in the past - it's easy).
More info about these diffs below.
Thanks!
~ Kevin
http://home.4x4wire.com/erik/diffs/
'86-95 IFS trucks and 4Runners, and all '93-98 T100s use a 7.5" front diff that is offset to the passenger's side. Later models came with ADD (Automatic Differential Disconnect) which uses a vacuum actuated mechanism to disconnect the drivers side axle shaft from the differential. Carriers and gear sets are interchangeable between the two different versions (and also happen to be the same as used in the 2wd Toyota pickup 7.5" diffs). One difference between ADD and non-ADD diffs is that the carrier in an ADD differential has needle bearings supporting the axle shafts at the differential. The non-ADD diffs did not have this bearing and sometimes the passenger side axle flange wears the carrier and becomes loose or wobbly, eventually causing oil leaks, noise, and possible spider gear damage. ADD and non-ADD diffs are swappable as are most of their parts. This makes it possible to change your ADD diff to non-ADD by simply swapping parts as I've done in the picture to the right. This is desirable to some people since some of the ADD stubs are smaller diameter than the non-ADD stubs and are therefore slightly weaker.
- Passenger's side
- Low pinion
- 27 spline axles
* This diff is based on the 2wd pickup 7.5" rear diff- same internals, different housing.
__________________
93 X-Cab
SAS on 37's
Kaptain is offline
Old 11-05-2009, 01:30 PM   #2 (permalink)
Do you have a matching rear?????
b4wheeler is offline
Old 11-06-2009, 04:37 AM   #3 (permalink)
Quote:
No, I don't - Sorry.
__________________
93 X-Cab
SAS on 37's
Kaptain is offline
Old 11-06-2009, 10:44 PM   #4 (permalink)
stormin94's Avatar
I'm interested, but shipping from PA would kill.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 11-07-2009, 08:57 AM   #5 (permalink)
[N8]'s Avatar
Quote:
FWIW, I bought an IFS front diff on another forum earlier this year from a guy in CA and it cost me roughly $70 to UPS ground it to PA.
__________________
| '91 4runner | 22RE | 5-spd | 5.29's | Locked F & R | 35" BFG AT's (no lift) | TG Rear Bumper | SS IFS Truss | AISIN Hubs | OME Steer. Stab. |
[N8] is offline
Tags
75, add, axle, diff, differential, front, ifs, pickup, rear, swap, swapping, toyota, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
