FS[FourCorners]: Alcan springs in Denver
I have a set of Alcan springs that I was running on my 88 4runner. Originally they were to stiff and were sent back to Alcan to get reworked and were sent back with extra leaves. They have no time on them since the rebuild and have the extra leaves in case you want to change the spring rate or ride quality. They were about 4-5 inches of lift but that will change based on your frame and how you mount them. I have a brand new bushing set for them and my old shackles will go with them too. $350 in Parker Colorado and shipping on your dime (80134, probably about $100 depending on where they go).
Width wise yes, but you will want longer shackles to compensate for the arch or the spring as they flex and essentially become longer, I will give you the shackles I was running with them.
So, I guess I didn't think my answer through real well before I posted, you will need to weld a new spring hangar onto your frame as these springs are longer than stock. Dimensionally they are stock spring, just longer.
live4soccer7
05-11-2016 06:52 PM
