FS[SouthCent]: 89-95 Cluster with Tach
Any offers guys, I hate to see this cluster go to waste but I'm not keeping it much longer.
It does come with the cover its just not in the pic.
Depends on if your truck is wired for tach. If not its just running a wire to the engine bay. Theres a write up on the site.
You will also need the oil pressure sender if you want to see your oil pressure. If not the you will need to disconnect the wire from your current sender.
Its a very simple and straight forward install. Just do a search on the site.
TheBFA
02-15-2020 06:55 AM
87SR5justin
09-29-2015 02:50 PM
