Engine, Transmission and Engine Bay-
-4.3L Chevy V6
-Holley aftermarket TBI unit- 670 CFM
-AA motor mounts
-Howell Engine harness and computer
-Aluminum Speedway Motors Radiator
-Dual batteries
-York Air compressor for OBA
-700r4 Transmission
-AA transmission to T-case adapter- new seal
-Extra cooler for transmission and PS for Hydro Assist
-Tapped Steering box
Transfer Case-
-Trail Gear 4.7 gear set
-Longfield Output
-All-Pro Ebrake
-Triple Drilled Rear Flange
-Fully rebuilt summer 2009 low miles
Driveshafts-
-Tom Woods full CV drivelines front and rear
Front Axle-
-1985 Toyota Axle
-Allpro High steer W/ Hydro Assist
-ARP hub and knuckle studs
-Fully trussed Using Marlin Crawler knuckle ball and main Truss
- Fully rebuilt knuckles, marlin crawler seals- summer 2008
-Hi pinion 4.88 third w/ ARB air locker
-30 Spline Longfield Axles
- vented rotors and IFS Calipers
-extended brake lines
-All Pro front Diff Protective Guard
Rear Axle-
-IFS rear end
-V6 third 4.88 gears Detroit locker geared by Marlin Crawler
-All pro chromo rear axles
-Allpro Disk brake conversion
-Marlin Crawler extended brake Lines
- New bearings, marlin crawler seals, third, axles, and brakes summer 2007
Lift-
-Allpro Solid Axle Swap
-3” lift springs throughout
-5” shackles front, 6.5” shackles rear
-UBolt Flip kits throughout
Flat Bed-
-Custom made using allpro design
-1.75 HREW .120 wall tubing
-One piece diamond plate bed and Diamond plate fender/wings
-incorporated spare tire holder
-Entire bed serves as an air tank with connection on drivers’ side
-Led Tail lights with Toyota to American tail light converter
-Bed liner sprayed on underside,
-Large enclosed storage bin bolted to bed
Cab-
-Alpine deck
-2- 6x9 3 way speaker
-2-3 ˝” 2 way front speaker
-CB radio
-Hunsaker aftermarket suspension seats
-ARB air locker and compressor switches
-B&M transmission shifter
-.50 Caliber Ammo can center console w/ lock
-Marlin Crawler full incab cage
- engine temp and oil pressure gage for 4.3L
Many extra parts from engine tune up to spare axles are included in the sale.
The good- The engine offers great power and it easily cruises at highway speeds. All drive train parts have been rebuilt in the last three years and have low miles on them (less than 3,000); I am in college and don’t have the time to drive or wheel that much. Tires are new and the spare has good tread life. Garage Stored, nice interior, and fluids changed regularly (Mobil 1 engine oil and full synthetic gear oil).
The Bad- Windshield has a bad crack and the passenger rear window is also broken. Rear window latch is broken also. The radiator needs a fan shroud built for the cooling system, runs warm on the trail on 90* days. Small coolant leak on the intake just needs a new gasket. And one small leak on the transmission between the adapter and transmission.
Castle Rock, CO
9,000 obo
Willing to trade for newer stock tacoma or 4runner
This ad is not displayed to registered members. Register your free account today and become a member on Yotatech!
