87 4runner 7mge project-Colorado Springs, CO-$1000 obo
87 4runner SR5
Truck was originally a 22re, I swaped a 7mge (supra engine) into it about 9 months ago (has been driven approximately 2K since swap).
Truck is currently not running, currently oil is getting into the coolant, I'm not sure what the issue is but I would guess it is the head gasket since that is a problem issue on these engines. However since I haven't taken the motor apart I cannot be sure.
The engine will run if oil is put into it (seems to run fine), however it cannot be left on for long or it will run out of oil.
I did a compression test on the engine and the numbers ranged from 138 to 150, the specs for a factory new engine is 156
Other issues:
Windshield and sunroof are cracked
needs a back window switch/window can currently be moved up/down by touching wires together
The truck does have brand new 31" tires (less than 5k on them)
The truck has a new exhaust (cat and muffler) with about 2k on them
transmission and 4wd shift with no issues
268k on the chassis
130k on the engine
I am not firm on the price, so make an offer!
feel free to give me a call if you have questions, if I don't pick up just leave a voicemail
719-650-4749
Ronnie
This ad is not displayed to registered members. Register your free account today and become a member on Yotatech!
