YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Vehicles - Trailers (Complete)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-30-2006, 01:42 PM   #1 (permalink)
hotshoe's Avatar
1992 Toyota Pickup in Souteast PA
92 4cly auto locked front and rear with 4:88's
35 Pro Comps with matching spare
Many new engine parts
Nice clean truck from original owner
See link for pics
Need a back seat for the family.
$5500.00 obo
hotshoe2@zoominternet.net for more pics and info
http://www.paragonap.com/forum/showthread.php?t=9525
__________________
92 Toy 1bl, sway away t bars, ball joint spacers, Chevy rears, 4:88;s ,35's, spool, lockrite, Chevy alloys, power tank, my sliders, my spare tire rack, my rear bumper,BudBuilt+1
97 T100, Stonewell Bodies Cap
Fully loaded for shoeing
I am the Toe Cutter! Have you seen the Night Rider?
hotshoe is offline
Sponsored Links
To remove this ad, register today!
Old 07-02-2006, 08:33 PM   #2 (permalink)
hotshoe's Avatar
to the top
__________________
hotshoe is offline
Old 07-06-2006, 05:41 PM   #3 (permalink)
hotshoe's Avatar
Comments? Questions? Offers?
__________________
hotshoe is offline
Old 07-09-2006, 05:04 PM   #4 (permalink)
hotshoe's Avatar
Would consider trade for stock 2gen 4runner,clean,5spd plus some cash.
__________________
hotshoe is offline
Old 07-14-2006, 10:44 AM   #5 (permalink)
Interested in the truck
I have a'75 FJ40 that seats 4 and has a rear bench installed: here are the specs:
1975 FJ-40 for sale
115k, desmogged, but inspected in PA, emissions exempt in PA if under 5k a year
Stock trans/xfer case/gears
33x9.BFG Muds (5) total on chrome 60 wheels, less than 3000 miles on them
Warn 8274 winch with 5/8” swaged tow truck cable
Body
Body is solid, floors are solid, cowl is solid, Ambie doors are rust free, new fenders, D/P doors have minor rust, red herculined interior, plate steel has been welded over the original tub in rear area, as well as new ¼ s and a new rear sill, no rust on the cowl, minor rust on tub (surface), no rust through, rear 1/4s have some damage and repair due to a Con-Ferr tire carrier that USED to be on the rig, more cosmetic than structural, some minor trimming has been done to the plate steel in the back so that ambie doors could fit after the plate steel was welded to the tub, running boards come with the rig but are not installed, HT is rust free except for some rust through in the rear corners where the top meet the body, both areas are about 3” in length, , body is inspectable for many years to come w/o doing anything
Frame has been treated with a 2 part marine epoxy and interior of frame has been pressure washed cleaned and waxolyed, new windshield
Following parts have been replaced in the past 5000 miles all receipts are available
Front end
-Disc brake swap with TLC parts, all new gaskets, bearings, rebuilt Warn hubs, rotors, calipers, shoes, master cylinder, rubber lines
-Mini truck PS swap, JTO bracket, JTO conversion line for use of Saginaw pump, Saginaw pump with wide pulley from a Volvo 240 (allows use of a stock width wide belt), steering stabilizer
Suspension
-Superlift shocks, Rancho Add-a-leaves in front, Rancho 4” rears, new u-bolts, greaseable springs pins, urethane bushings, HFS 1 ½” lift shackles
Fuel system
-New FACTORY STEEL GAS TANK, Jim C. carb rebuild, Kyosan fuel pump, soft lines
Cooling system
-JTO radiator, hoses, thermostat, gasket, housing, fluid heat riser
-GM 110 Amp HO alternator, Mean Green Starter, Intimidator gel battery, Pioner CD player w/2 speakers mounted on roll bar
Drivetrain
-clutch, pressure plate, TO bearing, Slave and master cylinder
Exhaust
-brand new header, gaskets, brand new complete exhaust routed ABOVE skidplate with a great quiet muffler
Extras
-Montero/Raider rear flip and fold bench seat as well as late model jumpseats, Con-Ferr grab bar, custom rear tire carrier with built in tail lights and box hitch, as well as a solid built in swing-out tire carrier, all wiring has been done for a 4 prong trailer hitch, full front roll cage (not installed) as well as extra steel to complete it and make a full family roll cage, extra birfs, mel’s ignition set-up, extra front and rear driveshafts and more…….
Needs
-wipers only work on low, you need to by a new switch
This rig has been offroad, approx. 20 times and has never let me down, I have made improvements on the rig to make it trail worthy of mild to intermediate trails without making any drivetrain mods, it is used not abused, and is not pretty but it is a perfect mix of a road worthy vehicle that you will not be afraid to wheel and scratch the paint
contact me at crawlin40@hotmail.com or Matt 610-683-7955
krawlin40 is offline
Old 07-17-2006, 11:40 AM   #6 (permalink)
hotshoe's Avatar
Matt- I assume that this is an offer for trade? Please send pics and location.
Thanks- Jim
__________________
hotshoe is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Service manual for 1992 toyota pickup??? earnhardt 86-95 Trucks & 4Runners 5 07-08-2008 08:03 PM
1992 Pickup NORCAL CLEANSR5 Vehicles - Trailers (Complete) 3 06-28-2007 01:59 PM
1992 pickup problems?? jigjew 86-95 Trucks & 4Runners 4 05-08-2007 02:42 AM
WTB: 85-88 toyota pickup or 85-89 4Runner Southeast PA toomanytoyzz Items Wanted 5 08-23-2006 04:33 AM
1992 Toyota pickup with 93 LT1 motor swap Wopicetti 95.5-2004 Tacomas & 96-2002 4Runners 5 07-27-2004 08:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
