FS[SouthEast]: 1992 4Runner with 3.4 5speed $2000
I hate to do it but I just don’t have the time or money to work on 2 4runners. I am selling this one because I need the other one at this time. This one is actually in better shape. On to the important info.
Vehicle is located at zip code 28034. 1992 4 Runner 4x4 3.0 V6 5 speed with 4.30 factory gears with a blown head gasket….shocking right? I do have a 3.4 with wiring harness and computer out of a wrecked 4runner. The donor was an automatic but I have already converted the harness to a 5 speed and have a computer to go with the setup. I have installed a 4crawler 2 inch body lift with new body bushings. I have the brackets to relocate the bumper and radiator from 4crawler but have not installed them. The 3.4 ran prior to purchase, I have sense removed the timing belt to replace but have not purchased the parts so I can’t start it for you. I do have a short video of the motor running prior to my purchase though. I have the vin# from the vehicle the motor came from and I have downloaded all the manuals from Toyota TIS for both the 92 and donor vehicle and can provide the buyer with both at time of pick up.
If you choose to make your own conversion harness I have all parts minus timing belt, water pump, and exhaust crossover pipe for the 3.4 swap. I do have the 3.4 manifolds and crossover if you choose to mod and make it work, plenty of links on site with instructions how to perform.
The 3.0 has been pulled but is still intact and will go with buyer for parts if desired at no extra cost. If not I will keep for my 91. Vehicle and motors must be picked up unless buyer arranges shipping. I can and will help load vehicle and motors for local pickup.
Pictures can been seen on build thread. https://www.yotatech.com/forums/f199...ild-up-283070/
The rims pictured on the 92 have been taken off but it does have the rims and tires from my 91 4runner, https://www.yotatech.com/forums/f199...-build-287039/ .
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
