YotaTech Forums
Go Back   YotaTech Forums > YotaTech Classifieds > Engines - Transmissions
Sign in using an external account
Register Forgot Password?
Search
Engines - Transmissions Place above type items here
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 05-13-2012, 12:35 PM   #1 (permalink)
Personal Sales Rating: (0)
donomite49's Avatar
for sale 1980 turbo buick eng/trans in nc
1980 turbo buick engine +trans. rebuilt long block. turbo 350 trans with everything 900.
__________________
88 xtra cab 4x4. 22re to 3.4 auto swap. cold air intake. obx headers, downey 2.5" exh. and frame brace. 3 core radiator. hayden trans cooler. chaos idler arm. v6 front brakes, trail gear rear disc's. kelly safari tsr 31x10:50's. to be charged after suspension http://www.youtube.com/watch?v=mbDqM9moOIg
donomite49 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 08-23-2012, 04:44 PM   #2 (permalink)
Threadstarter [OP]
donomite49's Avatar
new lower price
__________________
Old 11-26-2012, 09:10 AM   #3 (permalink)
Threadstarter [OP]
donomite49's Avatar
still have
__________________
Old 11-26-2012, 03:56 PM   #4 (permalink)
gmack192's Avatar
Is everything there and does (did) it run?
__________________
It would take some good old yodariggin
gmack192 is offline
Old 11-27-2012, 01:45 PM   #5 (permalink)
Threadstarter [OP]
donomite49's Avatar
i have everything from the manifolds, crossover pipe, 4 barrel carb, turbo(spins free).
the alternator, ac comp, and torque converter.
the engine was rebuilt by waynes engine rebuilders in Riverside CA before i moved from cali 12 years ago.
the intake or the timing chain cover and oil pan was never bolted on.
the block was replaced when rebuilt (cracked). iirc it was bored .040 over, forged flattop pistons, proper low compression pistons for the turbo application.
the heads are rebuilt and ported with the valve springs shimmed.
it needs new water and oil pump. it will need to be taken apart and reassembled to be sure..
motor has no rust and still turns.
so what i have is a known good engine that is a project that needs to be finished.
the trans has not been looked into.
i bought the whole car not running, i think it had around 150k miles the car looked like the PO had taken decent care of it, all original.
this motor is rated at 250 HP stock. i was going to put this into my 79 4x4 with downey's
stuff but ended up selling the truck.
__________________
Old 12-14-2012, 07:40 PM   #6 (permalink)
do you still have it? and if so I am in sc near charlotte and would like to come by and look at it if possible
jvmin is offline
Old 12-15-2012, 06:20 AM   #7 (permalink)
Threadstarter [OP]
donomite49's Avatar
still have, PM sent.
__________________
Old 03-11-2013, 09:15 AM   #8 (permalink)
Threadstarter [OP]
donomite49's Avatar
bump.
__________________
Old 03-11-2013, 04:14 PM   #9 (permalink)
1986YODA's Avatar
Just a lil info on the 3.8 turbo.... It's wasn't rated at 250 horsepower untill 1987.... I believe horsepower was 165 in 1980
1986YODA is offline
Old 03-13-2013, 03:33 PM   #10 (permalink)
Threadstarter [OP]
donomite49's Avatar
your right it is rated at 170 HP, 265 torque.http://www.beforeblack.net/evolution.htm
10 years ago i thought i read the 250 rating, can't remember where.
__________________
Old 03-31-2013, 02:48 PM   #11 (permalink)
Hello there. New to this forum. Might be interested in your motor for a project of mine. The intake manifold- Is it aluminum ?
LuckyLindy is offline
Old 03-31-2013, 03:12 PM   #12 (permalink)
Threadstarter [OP]
donomite49's Avatar
yes the intake is aluminum.
__________________
Yotatech
4WD Truck
Paid Advertisement
Tags
1980, buick, engine, engines, motor, nc, sale, toyoopencountry, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
