Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
I have for sale Downey 3.4 headers. Best headers for the 3.4! They will increase power all thoughout the power range and give you a great sound and give you maximum power out of your 3.4.
Ceramic headers No EGR but you can easily have a bung welded on for it if you need it. Im asking $400 shipped. Downey wants almost $500 brand new not including shipping. If your interested send Me a PM These headers havent even seen 100 miles Will include studs and nuts BEST HEADERS FOR THE 3.4!
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
| Sponsored Links |
#2 (permalink) |
I heard that headers won't help a 3.4 with a supercharger, is that correct or not?
__________________
99 4Runner LTD 4x4, Gen 1 TRD supercharger, complete URD fuel kit, IPT VB trans upgrade, Hayden 1679 tranny cooler, Dual Exhaust from cat back, Deckplate w/ Amsoil filter, Airraid Intake tube, Lotek dual gauge pod with Boost and Tranny temp, 2.5" Revtek Front Lift w/ diff drop, OME 891's rear with Monroe air shocks, ARB Sahara front bumper w/ IPT fogs, Warn XD 8000# winch, 285x75R16's Super Swamper TSL Radials on Ivan Stewart TRD wheels, Clear corners, Black Altezza rear lights. |
#3 (permalink) |
Ive never heard that. The headers increase the low end tourqe on these motors which the supercharger also I can only see these headers work in even better in your favor.
If I had supercharged mine I would definetly want these or atleast some type of header
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more Last edited by fillsrunner4 : 07-23-2008 at 02:54 PM. |
#4 (permalink) |
hummmmm tempting..
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan 89 4runner: Project DD. 3.0, needs a new tranny 81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg 91 Honda Prelude: the Daily Driver WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com |
#5 (permalink) |
fillsrunner4,
You wouldn't by chance need a new high-end custom desktop gaming computer that's watercooled do you? I've got one I just built and it is a complete custom build but I have no room for it at my house. I build computers and I'm a Network Administrator where I work. Let me know if you're interested. Thanks, Doug
__________________
#6 (permalink) | |
And??????
I could help you build the crosover too if you needed for a bit extra ![]() Quote:
Thanks
__________________
#7 (permalink) |
It has the following;
1. Lian-Li G50 Modified Black anodized aluminum case with custom windows in the side cover. 2. Asus A8N32-SLI motherboad, AMD 64 X2 4200+ Dual core processor, 2 GB PC3200 DDR RAM. 3. 500GB Western Digital Sata HDD 4. XFX 7900 GTX 512MB Nvidia PCI-Express Video Card 5. PCB Digital Sunbeam Phoebus Fan Controller for the 4 fans (3 - Radiator, 1 - Front) 6. Power Supply 600w OCZ GameXStream Power Supply 7. Complete Watercooling system; a. Laing D5 water pump b. Fill Port - Danger Den Black DD Fillport c. CPU Waterblock - TDX 939 d. Radiator - XFlow Stealth GTS 360 Black Ice e. Fans - 4 120mm Panaflo high power fans f. Blue UV Dye Coolant g. 2 UV Cathodes 8. Custom Front LED lights 9. XP Pro OS I actually have $800 into this system not counting the OS. I have not used the computer other than to load a fresh copy of XP Pro on the new Hard Drive, and installed AVG 8.0 and Adaware by Lavasoft, and check the system for coolant leaks and functionality. I don't have a spare monitor, keyboard, and mouse to use it anyway since I use my laptop for everything, so I figured I'd try to sell it. Right now it is only overclocked via the CPU multiplier and the FSB and it's runs awesome at 2.75GHz at 31* C. It has plenty more room for overclocking in that regard. I have the fans turned down to 50% and that is how cool it runs. The fans are controlled via the software program from Sunbeam which is loaded on it. I have a fold down front cover that matches the tower case for the dvd burner, but it is not on at this time due to the HP dvd burner doesn't function correctly. So the burner is just free with the computer. Thanks, Doug
__________________
99 4Runner LTD 4x4, Gen 1 TRD supercharger, complete URD fuel kit, IPT VB trans upgrade, Hayden 1679 tranny cooler, Dual Exhaust from cat back, Deckplate w/ Amsoil filter, Airraid Intake tube, Lotek dual gauge pod with Boost and Tranny temp, 2.5" Revtek Front Lift w/ diff drop, OME 891's rear with Monroe air shocks, ARB Sahara front bumper w/ IPT fogs, Warn XD 8000# winch, 285x75R16's Super Swamper TSL Radials on Ivan Stewart TRD wheels, Clear corners, Black Altezza rear lights. Last edited by 99SC4Runner : 10-28-2008 at 03:16 PM. |
#8 (permalink) |
99SC4Runner. Ill get back to you on this deal by this weekend. I have to think about it some. Looks like a real nice comp!
__________________
#9 (permalink) |
Bump still have the headers. will go as low as $350
__________________
#10 (permalink) |
Will they work with a 3.4 swap on a 2nd gen 4Runner?
__________________
1994 Toyota 4Runner SR5 4X4 208,000 miles and counting 3.0 V6, 5 speed 14/19 MPG city/hwy(before 33's) Current Mods Headers, 2.5" Flowmaster custom exhaust, K&N FIPK KC Daylighter 100 Watt lights Ranchos x4, 2" Lift Downey coils 33-12.50 M/T's, 1" t-bar lift, 1" body lift Tow pkg w/ lighthookups Silverstar Headlights, Pioneer Deck w/XM Brushguard 250Watt JLAudio 8" W3 Sub Future Mods
12V Aux outlet-400/800peak inverter roof basket/lights Air locker 4.88 gears H.O. Alternator |
#11 (permalink) |
thats exactly what I used it with. Ill include the pre and post cat 02's also if you want.
Great headers and work perfect with the 3.4 swap
__________________
#12 (permalink) |
Well.... my 3.4 swap is still in the early stages of becoming reality.
__________________
#13 (permalink) |
Bump still asking $350 shipped but will take offers
I know plenty of people here have these motors and want these headers. Im practically giving them away ![]()
__________________
#14 (permalink) |
Come on guys and girls! Doesnt anyone want the best headers for the 3.4?
Bump with a pic ![]()
__________________
#15 (permalink) |
whats welded on the top of the left header in the picture???
__________________
~Brian 89 Ex-Cab 3.4 Conv. T100 Tranny Yep i Changed it. Soon to be Supercharged. 90 4runner 3.0 Auto (Wifes Toy) I sold the HEEP I Havent finished my writeup but till i do heres a link to Mt_Goats write up http://www.yotatech.com/f116/3-4-swap-started-82145/ between him and i and a few others on here we should beable to answer most questions. |
#16 (permalink) |
its were the egr sensor goes. When I bought the header it came with the bung for it. I had it cut off and plugged shut. It affects the header very little.
__________________
#17 (permalink) |
PM sent.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: 3.4L Downey Headers | JGrund85 | Engine/Tranny/Parts | 11 | 10-28-2008 03:41 PM |
| Downey 3.0 headers, new | cadman | Engine/Tranny/Parts | 2 | 11-20-2007 07:03 PM |
