Bunch o' 22ret and 3.4 stuff...Downey headers too. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Engines - Transmissions
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-19-2009, 06:48 PM   #1 (permalink)
Ok, here's the final list of all my spare stuff...all the prices are off the top of head so make offers if you think I'm too high...or just high.
22RET Airflow meter: $50
22RET charge pipe from Turbo to TB $50
22RET turbo oil feed/drainback line $40
22RET injector resistor pack $30
22RET coil w/ ignitor, $40
22RET Distributor w/ newer cap/rotor/wires $50
22RET 4x4 oil pan and pickup $20
22RE/T crank pulley/balancer, new from dealer $75 (paid 160)
22RE/T balancer, no groove on seal surface $40
22RE/T rocker assembly. good shape, $40
22RE valve cover, $10
22RE starter, used $30
22RE starter, rebuilt, never used $75
stock SA L and R inners, $50
R151F turbo bellhousing $200
Front IFS diff w/ 4:10 gears and a trutrac $250 SOLD
Trans to engine brackets $10 each
A/C bracket w/ idler $20
A/C compressor (minus the fittings) $50
PS pump, used $25
PS pump, new ATSCO reman, $100
PS high pressure line (turbo specific) new $75
Lower turbo radiator hose w/ header hose tee, newer $40
Newer 22RE GMB waterpump, 8K miles on it. $25
2" tube OBD 1 cat, less than 1000 miles on it, $30
2.5" tube OBD 1 cat, new $50
From the 99 Tacoma prerunner doner rig
99 3.4L 4x4 A/T ECM - $100
2001 3.4 M/T 4x4 ECM - $130
Early 3.4L cast exhaust manifolds, no crossover $50
Downey 3.4L headers with crossover $350
Underhood fuse box w/ cut harness $20
interior fuse box $20
ECT switch $10
lbhsbz is offline
Old 10-19-2009, 07:34 PM   #2 (permalink)
RMA
You got PM...
__________________
'89 2wd X-tracab,W55,22re,My DD
'94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD
'88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907,
XRC8, Homemade Roof rack.33x10.50,15 KM2
1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake.
My swap thread
http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/
RMA is offline
Old 10-20-2009, 05:51 PM   #3 (permalink)
RMA
Payment sent , thanks !!
__________________
My swap thread
RMA is offline
Old 10-21-2009, 10:11 AM   #4 (permalink)
Send a message via MSN to Greg_Canada Send a message via Yahoo to Greg_Canada
Downey crossover, is it for a 3.4 swap or stock 3.4?
__________________
http://www.cardomain.com/ride/1147271/1 My 1989 Toyota 4runner
Greg_Canada is offline
Old 10-21-2009, 04:39 PM   #5 (permalink)
The headers were on a 99 tacoma 3.4L
lbhsbz is offline
Old 10-29-2009, 06:47 PM   #6 (permalink)
pm sent
jdmmike is offline
Old 11-18-2009, 07:27 PM   #7 (permalink)
Still have the 3.4 DT headers?
Libratsio is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
