YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-26-2005, 06:52 AM   #26 (permalink)
Roadrunner's Avatar
Maybe add a pry bar . . . and don't forget duct tape too.
__________________
Ian
2001 4Runner SR5 4x4 - An Evolving Expedition and Search and Rescue Response Vehicle
TJM, XD-9000 Winch, Badland Sliders, SAW/OME Lift, 33" MT/Rs, Homemade CO2 Set-up, Optima Blue Top, Cobra 75 WX ST, Icom V8000, Icom IC-F121, 1.0" 4Crawler BL, Hayden Tranny Cooler, Wilderness Rack w/Hella 550s, Snorkeled and Trail Armor by BudBuilt.
TLCA #14,082
SAR Field Team Leader - Shenandoah Mountain Rescue Group
Roadrunner is offline
Sponsored Links
To remove this ad, register today!
Old 08-26-2005, 08:42 PM   #27 (permalink)
kyle_22r's Avatar
i forgot a very important one, a PLASTIC HAMMER! great for putting the screws to some of the more sensitive parts.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 09-09-2005, 06:56 PM   #28 (permalink)
DH6twinotter's Avatar
Hey! I've just got a 89 (I think that's what it was) piece set of craftsman tools. I also have a torque wrench, a 4 pack of extensions, a universal joint, an adapter, a ten piece screwdriver set, a 4 pack of pliars, a hammer, a floor jack and a bunch of other little stuff. I've done timing belts and knock sensors with these tools, so you should be good to go for a while with some of these. Most of what I have I got by waiting for sales at Sears.
If you plan on doing a timing belt, you will also need a 19mm socket for the crank bolt.
Most of the other stuff is 10mm, 12mm, and some 14mm. The camshaft bolts are 17mm, but I've never messed with that. I'd like to find one of those spring scales like 86longbed has.
PB Blaster works great too!
Eventually, I would like to get some air tools.
Well, that's it! Have fun all.
Daniel
__________________
1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto.
15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick
Planned stuff: Pre-runner light bar with Hella 500s, small lift
Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow.
DH6twinotter is offline
Old 09-11-2005, 08:19 AM   #29 (permalink)
boylem002's Avatar
Ball Joint Press (MUST HAVE FOR UCA INSTALL!) you could rig something to work, though, but it probably won't be safe.
A good sized/strong C-Clamp for bushing installs.
line wrenches for brakes and tranny line removal/installs
Once you lift it, a bigger jack and jackstands! Replace that factory jack or you'll find yourself with a flat and no jack to lift the damned thing! Read: Hi-lift.
For some reason I've found many of the nuts on bolts that are way long, so you'll need deepwells in a lot of areas.
boylem002 is offline
Old 09-12-2005, 09:53 PM   #30 (permalink)
straightaxle85's Avatar
Send a message via AIM to straightaxle85 Send a message via Yahoo to straightaxle85
northeast toyotas loooove PB blaster
straightaxle85 is offline
Old 10-03-2008, 09:21 PM   #31 (permalink)
if you are doing suspension work. get a BFH a lot of pb blaster. goooood 19 mm 1/2 drive socket with a nice 25 inch breaker bar. BFH. pry bar. a floor jack to hold the axel. dont forget the high rise lifts for the body. did i mention pb blaster and a BFH? lol
for the shocks you will need a 17 mm
the rear diffs are 24mm head or if you had a fill plug like mine. a nice set of chisels, dead blow hammer, good sized vise grips, and a good amount of time.
T-case fill plug and drain plugs are also a 24 mm head.
if you have manual locking hubs for a 3rd gen taco dont forget the ball ping hammer to get the cones out of the wheel studs. and dont have a dumbass tightening the nuts onto the wheel studs or you get to have another fun half hour + taking the studs out to put new ones in cuz the nut threads were no longer there.
for timing belts 10 + 12 mm sockets and wrenchs, if i remember right you will also need a 19 for the crank to make sure your belt isnt a tooth off.
and the other asortment of BFH's, hammers, metric sockets and wrenchs, pb blaster, occasional SAWZALL, torque wrenchs come in handy as long as they are calibrated corectly.. and so on..
claudebadly is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
tool kit, whats required. dijlop Off Topic Talk 21 05-07-2007 02:10 PM
what is required for 33's? MattInTheCouv 86-95 Trucks & 4Runners 34 03-30-2007 06:19 AM
For those who do not use an anti virus tool or spyware tool Corey Computer Talk 11 03-05-2005 08:39 PM
Some assembly required Shane The Fab Shop 58 06-13-2003 12:57 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
