Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
What would you do with a couple of 9" iron plates?
Old 11-04-2011, 01:42 PM
pendrag's Avatar
I've had a pair of roughly square 9" iron plates, about 1/2" thick or so for a couple of years. I think they used to be used to hold train tracks on RR ties. They're mostly flat, but they've got a raised ridge on the top face and two lower ridges on the bottom face. They've got a some surface rust, but it'll grind right off.
I just built my first workbench, a 6'x2' top with a 1.5" thick plywood surface, and I'd like to do something with these plates - maybe make some sort of anvil out of one or both. I haven't bought a vice yet. I mostly work on my truck on the bench, but it's a general purpose work surface.
What would you guys do with these if you had them? How could I mount these flush with the bench top, given those ridges on the underside?
Top:
Bottom:
Old 11-04-2011, 02:05 PM
Elton's Avatar
go hang them from a tree and shoot at it with a ar15
Old 11-04-2011, 02:10 PM
pendrag's Avatar
You know, they really would make nice steel plate targets, but I'm not sure what the ridges and cutouts would do in terms of ricochets.
But assuming I wanted to use them somehow in conjunction with my work bench as a striking surface...?
Old 11-04-2011, 02:29 PM
wyoming9's Avatar
Smile
I would venture those are cast steel you are right track plates there must be trillions of them floating around.
I second use them for targets .
pick up a piece of 1/2" plate to beat on if you want
Old 12-11-2011, 05:27 PM
andor's Avatar
Meh wear glasses like ya should. shooting steel close and fast (like it's meant to be) means splatter.
In actuality I'd avoid it if it's cast, may actually shatter and be bad news all around. Use 'em as backing plates for your vise and anvil.
he's gone
7
12-03-2019 07:08 AM
jasonty
41
12-23-2018 01:00 PM
Jcrawl94
10
10-24-2015 04:34 PM
RobotMoose
09-02-2015 05:53 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: What would you do with a couple of 9" iron plates?
