Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
What kind of 220 volt outlet is needed for an air compressor?
I'm pricing out options on a new house and know that I eventually want to run an air compressor and possibly other tools that require a 220volt from the garage (welder?).
Here's the options on the pricing list: 220 Volt Outlet 30 Amp Circuit 220V 50 Amp Circuit w/Disconnect 100 Amp subpanel 110 Dedicated Circuit 110 GFI Outlet 110 Outlet 110V Floor Outlet Which of these do I need? I don't know nothing about electrical stuff.
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB 99 4Runner SR5 Black - 57k miles, E-Locker, Daily Driver 06 Girl - destoyer of all things fragile 08 Boy - a fat little hairy sumo wrestler |
| Sponsored Links |
#2 (permalink) |
the 30amp i believe.... the disconnect would be for something even bigger i think, and permanent...
a separate subpanel would be really nice because from there you could add any needed circuits in the garage, including the 220 the dedicated circuit would be for something like an alarm system maybe, or a clock, or emergency exits/lighting, or anything you don't want to go off, if you blow a circuit the GFCI would be for anything close or possibly near water, or something that a grounded ext cord could be plugged into that would be near water or outside... I think thats the basics...
__________________
Andrew J W = WJwerdnA '99 4Runner SR5 - Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi - AIM:wjwerdna YotaTech Profile Custom Bumper Link for sale: "six-spoke" stock alloys, PM if interested :) ... also, stock running boards, pm offer, and stock panhard bar, great for mod'ing longer for lift adjustment |
#3 (permalink) |
if you plan on getting a decent welder i believe 220 50 amp, i sure you will be pointed in the right direction
#4 (permalink) |
check around at welder websites, or local welding shops if there are any,,,, they would be able to tell you I am sure
__________________
#5 (permalink) |
Any of these can be wired for 220V, but the last two give you the amperage to run anything. The easiest is probably just to go with #2 since the max the 100 Amp subpanel (assuming it's a 110V incoming line) could be wired for would be the same thing (220V, 50A). Just as an FYI, most well built garages will usually run 100 Amp subpanel AND a 220V outlet (either 30A or 50A.......for most people the 30A is fine even with a large air compressor or welder, but a very large MIG or TIG may need more power) AND a 110V outdoor GFCI outlet.......and that's probably what I would run if I was doing it.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner : 03-02-2007 at 10:31 AM. |
#6 (permalink) |
Definately a 100 amp subpanel, from there you can add any circuit you need.
Once I finish cleaning up my garage, I'll be wiring in my subpanel, from there a 220v 50a circuit for my TIG welder with slow blow fuses, then a 220v 30a for my compressor and finally a bunch of 110v circuits for the rest. |
#7 (permalink) |
Staff
I love you electricians! I was wondering about this too.
__________________
Molly aka Lysmachia 93 4 Runner SAS - All Fixed in Junk Yard Goodness Get your 4x4 VIDEO pr0n here |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Removing Air Conditioning or converting to air compressor??? | NMcruser | Offroad Tech | 8 | 11-28-2008 01:46 PM |
| A/C Compressor turned Air Compressor | Kiff | 86-95 Trucks & 4Runners | 13 | 08-15-2007 06:59 PM |
| 12 Volt Outlet Problems!! | codeman720 | 03+ 4Runner/GX470, & 05+ Tacomas | 3 | 03-14-2007 07:13 PM |
| WTB: pop can sized air compressor (for air horn) | Brendan | Items Wanted | 1 | 01-03-2007 08:13 PM |
| I need a compressor for my air horns | Brendan | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 11-12-2004 10:18 PM |
