| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Welders for body work and light frame welding?
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. Last edited by CJM; 02-03-2008 at 07:02 AM. |
#2 (permalink) |
that hobart should do it ok, if it was a 140 it would be better. the 125 will weld 3/16" pretty easy, so should weld on a frame ok. the only problem is welding sheet metal, you'll probably burn through it until you get the hang of it.
__________________
2003 4WD TRD Tacoma 1986 4Runner |
#3 (permalink) |
yeah but if you use lots of tacks you can get some sucess ive found hahaha
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#4 (permalink) |
Well we shall see. I just removed about 80% of the rust. 2 body mounts, and god only knows on the frame cause i cant see much.
800 bucks for a rust bucket, shoulda just waited on here and drove to get one..
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#5 (permalink) |
dudde it might look bleek but 800 for a gen 1 is good...you need a parts truck is all just wait...when it warms up a little tlc goes along way.... i have my old 94 that 2 deer ran into me that im getting some used tires for and cant wait to wrench on in the spring...
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ Last edited by bigt; 02-03-2008 at 01:05 PM. |
#6 (permalink) |
Well, rust is the big thing, this truck tbh would be a better donor truck. I need to find a welder i can use and be happy with, cause right now 2 of the mounts are really bad and one is iffy.. I aint even taken it off the frame yet and cant wait to see what I find.
WHat I need is a 110v a/c welder that will do the job, maybe take more time but do it. I dont care if i have to do multiple passes, clean up the job or such either.
__________________
#7 (permalink) |
yup i got a nice little lincoln 110v works good...just tack.... im still learningmyself and when spring hits us im going to tackkle my old daily driver that 2 deer ran into the side of and fix the rear door and body work ....if you take your time and like you said clean up the welds we shoudl be fine.. i would buy a 120v welder or bourgh one
__________________
#8 (permalink) |
Pretty much.. I may have to wrangle the shop welder down, mig wire feed but were always busy there and its inside..ha try putting the truck in the bay
__________________
| Tags |
| amp, body, bodywork, forums, frame, locations, mounts, put, sameri, samurai, suski, suzuki, toyota, welder, welders, welding, work |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 85 body to 92 body but keep the 85 frame help is it worth it | straightaxle | All Other Toyota Swaps | 1 | 12-31-2008 08:14 AM |
| Tips for welding on a Toyota frame? | Hasbeen | General Vehicle Related Topics (Non Year Related) | 8 | 01-16-2008 04:21 PM |
| custom metal work...welding and cutting... | Yay_area_408 | The Fab Shop | 13 | 04-11-2007 08:07 PM |
| re-welding to the frame | jacksonpt | The Fab Shop | 5 | 10-11-2005 04:52 PM |
| Welding sliders to frame | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 09-23-2003 09:50 AM |
