| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Stupid cone washers, on solid axels
#2 (permalink) |
heat them up owith a torch then hit the side of them or the flange and they will pop like pop corn
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan, 130,000 km 31 bfg a/t auto current build 1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/ |
#3 (permalink) |
Hit the studs with a brass bar. After a couple hits they'll come right off.
__________________
MY BUILD |
#4 (permalink) |
Some ideas:
- http://www.4crawler.com/4x4/CheapTri...eWasherRemoval And note that I have never run into one technique that will work with every single cone washer. All depends on what it holding it tight. So if you try one technique and get say 4 of the washer off, but 2 won't budge. Try something else on them. I have had some that literally fly off with the slightest tap of a hammer and others that are stuck on the stud and no amount of hammering will make them move.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 06-05-2008 at 07:45 AM. |
#5 (permalink) |
Thank You, And I think the "anti-sieze" will help.
#6 (permalink) |
Anyone ever use a toy hub puller like the ones hendrix motorsports used to sell?
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#7 (permalink) |
Super Moderator-Sponsoring Member
Staff
I have taken off hundreds of cone washers and it is pretty easy.
Patience and know how. Not everything in life requires brute force. Nothing sickens me more than to see a set of abused steering arms or manual hubs removed by an obliviot. Clean the area of mud and debris. Apply some lubricant like PB Blaster Use a brass drift and a hammer to TAP, not beat the ever loving crap out of, on the stud and surrounding areas Use patience and work around If one wont come off immediately try another Once one is off the rest loosen up quick Never any need to get abusive with the hammer Never any need for heat Work smart not hard. ![]()
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#8 (permalink) |
I used my brick hammer when I took mine off. It's got a square, flat head, and is offset from the handle about 3 inches. The head went right over the top of the hubs. I just had to hit the end of the stud a couple of times, just tapping, not hard, and the washers popped loose.
Other than that, Wabbit is right on
__________________
Trail Truck: 84 regular cab 85 22r -- streetRV head, 261C cam, 2.5" flowmaster, lock-right in rear, 1" Wabfab BL, IFS brakes, rock sliders, diff breathers, Amsoil, dual cases, front rock lights, tube bumper, 33x12.50 BFG MTs, cryo'd 5.29s, RUF, 213k miles ---Currently: Misc ---Next: Front bumper Link to build-up: http://www.yotatech.com/f115/jmazoso...uildup-137611/ DD: 01 Tundra V8, 3" flowmaster, FIPK, JBA Headers 133K miles |
#9 (permalink) |
I use an air chisel to remove mine. Your probably thinking I'm an idiot but it works great if you do it right.
I just thread a bolt onto the stud part way so its like a dish and protects the threads. Then I use the pointed attachment on my air chisel and give the end of the stud a quick zap and the washer pops right off. I've done it many many times and have never damaged anything.
__________________
1985 4runner 22re 5spd. |
#10 (permalink) |
AHH ZOMBIE THREAD !!!
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#11 (permalink) |
Anything under a year isn't really a zombie thread.
__________________
#12 (permalink) |
I just figured this out. I threaded the nuts on the ends of the bolts, used a little muscle, some determination and allot of focus.
See Also: http://www.barneymc.com/TOY_ROOT/TECHNEEK/conewash.htm http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml Last edited by jeebus; 03-18-2009 at 07:00 PM. |
| Tags |
| axelscom, axle, buy, cone, hilux, install, remove, removing, solid, special, split, tool, toyota, washer, washers |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Cone Washers for knuckle arms | Tylerars24 | Solid Axle Swaps, All Years | 2 | 11-15-2007 08:44 AM |
| Where to buy cone washers? | Viet0ne | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-05-2005 08:35 AM |
| front hub cone washers | lal357 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 08-05-2005 08:10 AM |
| cone washers on 88 yota truck | ohioyotaguy | Maintenance & Repair Archives | 22 | 09-29-2004 10:09 AM |
