Sign in using an external account
| Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#26 (permalink) | ||||
Personal
Sales Rating: (1)
[OP]
__________________
Phil | Pleasanton, CA |1987 4Runner SR5 DIYs (Photos!): |
#27 (permalink) |
Personal
Sales Rating: (0)
He I hope means the breaker you are using is in the open position.
This is where so many people get screwed up in wiring. In the newer homes they are all using a 4 wire cable to hook up any208/ 220/240 VAC. Stoves/Ac/ Dryers etc. What ever you may have. In industry most all single phase equipment still comes with the 3 wire cable. Black /white/ Green With green always the ground Only in 3 phase does one see the red wire which is always going to be or should be the third leg. It can get real confusing fast. That is why I said to check how the Female plug is wired just to be safe in case it is not wired to code. Your Multimeter is your friend If you have questions feel free to Pm me. |
#28 (permalink) | |
Personal
Sales Rating: (0)
Quote:
"Only in 3 phase does one see the red wire which is always going to be or should be the third leg." it should read Only in 3 phase does one see the blue wire which is always going to be or should be the third leg. single phase black (1st hot) red (2nd hot) philbert sky pilots telling you just to be sure to turn the main breaker off. and again green wire would go to the L shape prong ... some appliances it would matter where the black and white went ...but on the welder it doesn't ...black and white to the flat prongs
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, HM Roof rack.33x10.50,15 KM2 1" HM body lift, BJ spacers ,CB, rear disc ,lockright rear, Truetrac front,HM IFS truss,HM sliders,HM rear bumper,HM crossmember,CO2,2 batts,softopper. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
#29 (permalink) |
Personal
Sales Rating: (1)
[OP]
Thanks Robert.
Again, still conflicting info about the wires, but if you say the white/black doesn't matter, and others are saying it does....I'm going to wire it up like they say, since the green seems to be for the L shaped prong, according to everyone else's post here...and if it doesn't matter where white/black go, then it won't hurt to follow the specific directions for them posted here earlier ![]() thanks guys
__________________
#30 (permalink) |
Personal
Sales Rating: (0)
just to throw a little more out there when u go with 220v set ups u are better 4unning 4 wire set ups due to having an extra ground in there, but in "most" cases when u look at 3 wire 220 setups it is ran as black wire is 120 or hot... white 120 or hot and green or copper neutral or ground... now if u use 4 wire. it is black 120 hot, red 120 or hot, green ground, white neutral... so now that the electrical lesson is done... go weld and have fun building things...
#31 (permalink) |
Personal
Sales Rating: (0)
in this case with the welder it doesnt matter, as long as your running 110 thru black( Phase A) and 110 thru white (phase B) and ground green your ok there is no nuetral for 220 the hot wires are out of phase from each other and complete the circuit for one another.. you cannot do 110 thru black (phase A) 110 thru white (phase A).. larger compressors for example it does matter but your not hooking up a larger compressor to the dryer plug.
.. "and if it doesn't matter where white/black go, then it won't hurt to follow the specific directions for them posted here earlier" which ones are you referring to?
__________________
#32 (permalink) |
Personal
Sales Rating: (1)
[OP]
#33 (permalink) |
Personal
Sales Rating: (0)
Interesting all the 4 wire soow cable I have come across is Black, White Red, and Green I have yet to see any with Blue.
i am out in the field doing this every day Is this something new ?? That all the older cable will be declared unsafe because of color and need to be replaced. More things to send manufacturing off shore. Such is life |
#34 (permalink) | |
Personal
Sales Rating: (1)
Quote:
Older wire is dangerous. I have zinc plated copper wire in my house with cloth insulation inside armored cable. I have all the outlets pigtailed due to arcing at the outlets. When you see a wire eaten away you understand how fires start. I use a nasty wire nut to cut into the wire and make a solid connection until I can get to replacing every foot of that junk. |
#35 (permalink) |
Personal
Sales Rating: (1)
__________________
--Ian red 93 pu dlx 22rec 5sp 4x4, 196k and rising Build Thread: the Red Rover |Last »| my 22r-e rebuild (lots-o-pics) my trailer build |
#36 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
Matt 87 4runner SR5, 5speed, 22r-e To get Factory Service Manual downloads: http://www.yotatech.com/f115/fsm-nea...manual-156129/ Last edited by Buck87; 02-21-2012 at 07:32 AM. |
#37 (permalink) |
Personal
Sales Rating: (0)
this is correct..but your earlier statement "only in 3 phase does one see the red wire" is not as your explaining now red is found through out single thru to 3 phase..the blue is ONLY found in 3 phase and 3 phase is only found in commercial wireing...not residential and does not have anything to do with this thread because he does not have 3 phase but i thought id correct the statement anyway..
__________________
#38 (permalink) |
Personal
Sales Rating: (1)
[OP]
Hooked up
OK, finally got the plug hooked up - let me know what you guys think?
The "L" prong seems to have some slight give to it when wiggled, despite being seated in the groove on the opposing half of the plug module.... ![]() ![]() ![]() ![]() Have not plugged it in yet - that's further down the road, and I've been really busy with work work lately.
__________________
#39 (permalink) |
Personal
Sales Rating: (1)
looks good to me
__________________
#40 (permalink) |
Certified Goat Herder
Personal
Sales Rating: (10)
Staff
I wish you the best of luck Phil with that welder but the fact it came without a plug is a big tip off IMO. For a little more you could have purchased a name brand welder used/new and got a plug and much more. As one who works on Toyotas, I'd never use flux core except on a tractor or something I didn't care what it looked like.
If you learned doing MIG, you are not going to like the mess FC makes.
| Tags |
| 140, 220v, 97503, amp, cord, freight, harbor, male, mod, plug, power, prong, welder, white, wire |
