So I'm hooking up my new welder and... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Sign in using an external account
Register Forgot Password?
Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-15-2012, 09:57 PM   #1 (permalink)
Personal Sales Rating: (1)
Philbert's Avatar
Recently I bought this 120 AMP Harbor Freight Flux Core welder for spring swaps, exhaust work, etc:
http://www.harborfreight.com/120-amp...der-97503.html
It came with a short power cord and, no plug.
I wanted a longer cord since I was going to use the dryer outlet just inside the garage/house door.
I bought a 25 foot long 10 AWG cord from Home Depot, with the same white/black/green interior wire scheme.
I also bought this Leviton plug:
http://www.leviton.com/OA_HTML/ibeCC...&section=10918
The plug came with the following schematic, for the flat/flat/L prong setup for dryer plugs (the top diagram here):
So, here is my question.....
Do I simply hook up the white and black wires to the 2 flat prongs, and the green wire to the L prong (this is ground, right?)?
If so, does it MATTER which of the 2 flat prongs the white/black wires attach to or are they interchangable?
I've spent a pretty good deal of time researching this and frankly, I'm just not comfortable with what I'm finding online - it's not conclusive....and I'd rather hear it from those here who have set this up.
Thanks in advance folks,
Phil
Philbert is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-16-2012, 05:36 AM   #2 (permalink)
Personal Sales Rating: (0)
Buck87's Avatar
Subscribed,
I think you have the right idea, both the white and the black are hot so they are interchangable, but I want to hear it from someone who is sure.
__________________
Matt
87 4runner SR5, 5speed, 22r-e
To get Factory Service Manual downloads: http://www.yotatech.com/f115/fsm-nea...manual-156129/
Buck87 is offline
Old 02-16-2012, 05:52 AM   #3 (permalink)
irab88's Avatar
ianrab
Send a message via Yahoo to irab88
black and white are not interchangeable. black is "hot", white is "neutral", green is "ground".
i'm looking for a good pic now...
__________________
--Ian
red 93 pu dlx 22rec 5sp 4x4, 196k and rising
Build Thread: the Red Rover |Last »|
my 22r-e rebuild (lots-o-pics)
my trailer build
Quote:
Originally Posted by xxxtreme22r View Post
can't "fix" EFI, it has a mind of it's own
irab88 is offline
Old 02-16-2012, 06:15 AM   #4 (permalink)
irab88's Avatar
ianrab
(gray = white)
__________________
--Ian
my trailer build
irab88 is offline
Old 02-16-2012, 06:28 AM   #5 (permalink)
I have hooked up several welders. The previous post is right in that white is neutral and green is ground and they are two different things. In the case of this welder the original post has the right idea green to the one marked W and the other two wires to the X and Y. I'm assuming that the harbor freight welder you have is 220v and you are wiring it into your main breaker box and not a subpannel.
93yota22re is offline
Old 02-16-2012, 06:33 AM   #6 (permalink)
RMA
RMA's Avatar
green wire would go to the L shape prong ... some appliances it would matter where the black and white went ...but on the welder it doesn't ...black and white to the flat prongs
__________________
'89 2wd X-tracab,W55,22re,My DD
'94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD
'88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907,
XRC8, HM Roof rack.33x10.50,15 KM2 1" HM body lift, BJ spacers ,CB, rear disc ,lockright rear, Truetrac front,HM IFS truss,HM sliders,HM rear bumper,HM crossmember,CO2,2 batts,softopper.
My swap thread
http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/
RMA is offline
Old 02-16-2012, 06:36 AM   #7 (permalink)
Threadstarter [OP]
Philbert's Avatar
Thanks Ian and 93yota.
I am planning to use the dryer outlet, which is in the room between the garage and house interior. This is a 200V welder, yes.
Earlier I said it was 10 AWG wire....actually, the wires INSIDE the thick wire sleeve are each 10AWG. Here is a photo of what I have:
So, Sounds like Ian has it right with the diagram? Going to wait a day in case anyone else jumps in (no offense Ian!!).
Thanks again guys!
Philbert is offline
Old 02-16-2012, 06:47 AM   #8 (permalink)
irab88's Avatar
ianrab
none taken. if it turns out i'm wrong, i've learned something
__________________
--Ian
my trailer build
irab88 is offline
Old 02-16-2012, 06:52 AM   #9 (permalink)
"Going to wait a day" man you have a whole lot more patience or is it self control then I do. Just while I'm thinking about it. It sounds like this is your first welder. If you are going to be using flux core instead of solid wire with gas you will most likely need to set the machine to DCEN. Basically make sure the gun is hooked to the negative terminal inside your machine. If you run into any snags or welding questions let me know i can talk about melting metal all day.
Old 02-16-2012, 08:19 AM   #10 (permalink)
91mtngoat's Avatar
They are correct in the placement of the wires. White and black are both +, green is -. 220 needs two positive terminals which are at opsite waves. 110 only needs one. All houses have 220 (2 positive lines) running into the breaker box. A 110 (single breaker) sends one + wire to the plug and 220 (double like you are using) sends two + wires (black & white). Green wire in the plug is connected to the ground bar in the breaker box. Hope this helps.
__________________
Stiff ifs, rear lockright, custom bed & sliders, ramsey 9500 won in raffel for $20, 31000 origional miles, bought in '03 for $3000.
91mtngoat is offline
Old 02-16-2012, 09:16 AM   #11 (permalink)
neil_P_smith's Avatar
mtngoat is right
220 uses 2 hot and a ground (a phase(black) and b phase(white)); 110 is only one hot(black), a negative(white), and a ground(green).
__________________
"57. You have not made any mistakes if you find that there are extra pieces after reassembling or assembling an object. In fact, you have just found a way to make that object more efficient."
stock '93 short bed, rebuilt most everything, want 32" tires and lockers
82 20/22r 3" body lift 3" spring lift, dual cases, detroit rr, lockrite fr, 5.29's,36"tslsx, m8k warn (lost)
neil_P_smith is offline
Old 02-16-2012, 09:47 AM   #12 (permalink)
Buck87's Avatar
Friday Harbor! I've been there. How is the wheeling on the islands?
__________________
Matt
Buck87 is offline
Old 02-16-2012, 10:12 AM   #13 (permalink)
westjohns yota's Avatar
josh westjohn
off topic but how much did you pay for that? i need a welder for all the stuff i do!
__________________
1987 toyota shortbed, 22r 5spd sittin on 31 bfg A/Ts . 261 rv cam -sold like an idiot
1982 toyota longbed, 22r 5spd, 5in springs, -sold
1986 toyota long bed, SAS, 22re, 5 spd, 5in springs, 5.29s. detroits front and rear, 36in tsl swampers, mile marker 12k winch on the front for ur sticky stuff!
"anything you can do my toyota can do a WHOLE lot better........"
westjohns yota is offline
Old 02-16-2012, 10:35 AM   #14 (permalink)
check out the millermatic 211 mvp series.
capable of using 115 and 230v. You can choose settings between voltage.
I love mine, welds smooth and is perfect for light farm/auto work!
http://www.welders-direct.com/mm5/me...ory_Code=m-mig
BC76 is offline
Old 02-16-2012, 10:45 AM   #15 (permalink)
irab88's Avatar
ianrab
+1 for that thing. i'm using a 130 and flux-core, and it's fairly smooth. i love the thing (heavy as hell, though)
http://i1179.photobucket.com/albums/...8/CIMG8789.jpg
that's it for my thread-jack
(i need 220 in the garage, now that i think about it)
__________________
--Ian
my trailer build
irab88 is offline
Old 02-16-2012, 11:19 AM   #16 (permalink)
Red face
I hope you are attaching your new input cord inside the welder!!! The plug you bought is the male counter part to the female plug.
It always pays to double check just how the female plug is wired I have seen some dumb things in my day.
Make sure all your connections are good and tight.
Loose connections get hot real fast.
I wish you well with this welder. Sometimes one has toi do what one can
wyoming9 is offline
Old 02-16-2012, 01:01 PM   #17 (permalink)
Threadstarter [OP]
Philbert's Avatar
Thanks everyone!!
I've actually had the welder since October (had the Datsun in the garage from Sept-Dec, then did my W56 swap on the truck in January and finished up last week. had the Chevy springs since October too...so I've been exercising some patience you could say
Yes, I do have the 3 wires on the new longer cord hooked up INSIDE the welder - I hooked them up exactly like the previous wires were done, so it should match up perfectly.
I took a class last summer with MIG and LOVED it - can't wait to get started. just need to find some scrap to practive on....
Cheers!
Phil
Oh, and I paid $180 for the welder plus $35 for the 27 month added warranty. It normally sells for $299 but is on sale for $199 a lot it seems. I bought it, then found an ad for $179.99 a week later, took it in and got $20 back
I know it's not a Lincoln or Miller but it fit my budget and is really well reviewed...and I got the warranty.
Thanks again everyone!
Philbert is offline
Old 02-16-2012, 02:02 PM   #18 (permalink)
josh westjohn
Will def consider buying one, I really need a Welder and have for awhile
Old 02-17-2012, 04:14 AM   #19 (permalink)
When I got my plasma from HF I heard something loose in there moving around. I took it apart. Turned out to be a 3/8 inch chunk of glue which was probably harmless but also found a 2 inch long shiner floating around...not harmless. The cheapo plasma's do not have as good reputation as the welders do, but so far, with limited use mine works great.
Just wondering, is there any way to put a gas bottle on that? FC is good for exhaust and body work, but I heard it requires more current than bare wire. You may be pushing it when you get to frame work. I have a Lincoln 110 w/0.023 wire and 80/19/1 gas, it works pretty hard on 1/4 inch, so be careful and watch your Duty Cycle.
sixstringslut is offline
Old 02-17-2012, 05:26 AM   #20 (permalink)
Threadstarter [OP]
Philbert's Avatar
There is a tube for gas, if you want to go that route.
I don't care if my welds aren't pretty, for what I'm doing. This welder was recommended by a guy in Georgia (totally spacing on his name here....) who did the spring swap on his 4runner. I think I'll be OK as long as I take my take and watch the duty cycle, etc.
Thanks!
Philbert is offline
Old 02-17-2012, 02:26 PM   #21 (permalink)
Buck87's Avatar
Flux core will give you better penetration, and you wont have to worry about the shield gas blowing away when you are outside.
That said I much more enjoy welding with gas. Cleaner welds and my shop does not fill up with smoke.
__________________
Matt
Buck87 is offline
Old 02-19-2012, 12:24 AM   #22 (permalink)
Red face
It is a shame you are only making it harder on your self trying to practice on scrap. You will spend more time cleaning then welding.
Remember the prep work is 90% the rest is the welding.
Best of luck.
wyoming9 is offline
Old 02-19-2012, 12:40 AM   #23 (permalink)
Threadstarter [OP]
Philbert's Avatar
Best of luck.
Well, I'd rather learn on something than learn for the first time on my frame I don't mind cleaning a little scrap to learn to weld the real thing better!
Philbert is offline
Old 02-19-2012, 02:47 AM   #24 (permalink)
skypilot's Avatar
skypilot123
Quote:
Originally Posted by Buck87 View Post
Subscribed,
No they are not.
Black & red are hot! White is neutral and is grounded at the electrical box & no where else. You hair dryer or lamp do not care but electrical motors sure do!
between white and a red or black is 120VAC. between black & red is 240vac.
between white & green is 0.0 But white is not green.
Follow the diagram, and make double damn sure the feed breaker is open! first thing in the box is your meter to make sure its a dead line. I do not need anymore funerals, I attend to damn many as is.
skypilot is offline
Old 02-19-2012, 06:18 AM   #25 (permalink)
the color of the wires is not important. the person who hooks them up decides which wires are hot and which is neutral or ground. when hooking up 220v with a black and white conductor most electrcians will wrap the white wire with red or black electrical tape to show it is a hot wire.they have everything under control with the wirering, everything will work fine. when in doubt get out the multi meter.
toyrunnerns is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
140, 220v, 97503, amp, cord, freight, harbor, male, mod, plug, power, prong, welder, white, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
