YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-31-2007, 11:16 AM   #1 (permalink)
mjwalfredo's Avatar
Send a message via AIM to mjwalfredo
Sheared rear swaybar bolts, Too late for easy out - What should I use?
Hi Guys,
During some wrenching, I needed to remove the rear swaybar from my 3rd gen 4 Runner and sheared both bolts that attach the the bar to the axle on the passenger side. I tried to use an Easy-out like tool but I kept breaking them so I lost my cool and started drilling into the bolt studs. This was stupid especially now that I've got a new room mate who knows how to use an easy out correctly (Didn't know about this at the time)
So now my plan is to drill out both bolt studs to make a bigger hole and just use bolts/nuts/washers to attach the swaybar. Here is my problem, the tab on the axle that the sway bar is bolted to has a nut welded to it. I want to cut this off but there is maybe 1-1/2 inches of space around that nut inside the tab. Anyone have a good suggestion on what to use to cut thru the nuts? I've got access to a dremel so if there is a good attachment for it that would be awesome.
__________________
-Marcus
1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo
mjwalfredo is offline
Sponsored Links
To remove this ad, register today!
Old 05-31-2007, 11:22 AM   #2 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
they make small cut off wheels for the dremel...
Could you just drill through the nut to get rid of the threads, and make that hole bigger also?
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 05-31-2007, 11:24 AM   #3 (permalink)
mjwalfredo's Avatar
You know what, when I get home today, I will see if there is enough room between the axle and the existing nut for another nut and the threaded part of the bolt. That sure would make things easier, thanks Rocko!
__________________
-Marcus
Old 05-31-2007, 11:25 AM   #4 (permalink)
more than welcome!!
__________________
Great Toyota Tech
Old 05-31-2007, 11:29 AM   #5 (permalink)
surf4runner's Avatar
be happy the broken easy-outs came out easy mine is still stuck
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 07-30-2007, 03:22 PM   #6 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
Just leave the remnants of the bolts in there. You don't need a swaybar anyways. I had a set of swaybar discos and one day when my truck was all muddy I didn't put them back in. I drove it home like that and realized that I didn't need it at all, so off it came. That was like 6 years ago. I did the SAS and I really have no need for it now.
__________________
Rome the "Seafarinman" IT1(SW) US NAVY
1994 SAS 2RZ/R151F=244:1!
http://s11.photobucket.com/albums/a176/seafarinman/
seafarinman is offline
Old 08-08-2007, 09:22 PM   #7 (permalink)
nix4x4's Avatar
shoot i had mine off the other day and its IFS... very slight change that i mightve not even noticed had i not been the one who removed them. But as far as stuck sway bars/ endlinks go, the whizz-wheel is your best friend.
__________________
The Stable...
2002 Toyota Tundra SR5 AccCab V8 4WD
1992 Toyota Truck DLX Xcab V6 5-speed 4WD
1995 Honda Accord LX 4 door I4
Check out my sweet myspace
nix4x4 is offline
Old 08-09-2007, 06:18 AM   #8 (permalink)
mjwalfredo's Avatar
I hear you guys about driving without the swaybar on. I have been without my rear for a couple of months now and I don't think that it is too big of a difference, especially with the Bilsteins on my truck. It is noticeable I believe though so I want to at least put it back on with my new poly bushings for a comparison.
By the way, it appears that there is not enough room to simply use a nut between the nut welded to the mount and the axle. I was at home depot and I saw a fiberglass (I think) cut-off wheel that I will try and use to remove enough of the nut fit a new one on there. I'll post about the proccess when I get around to it.
__________________
-Marcus
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Advice on how to remove sheared off bolts harpen123 Tool Time 15 06-28-2007 09:57 PM
*SNAP* Rear Axle sheared off at 45mph and tire went for a ride! Lysmachia 86-95 Trucks & 4Runners 130 05-13-2007 11:45 AM
Rear swaybar drop bracket? SC4Runner Offroad Tech 6 10-03-2005 08:35 PM
Swaybar endlink sheared...pics ssbogger 95.5-2004 Tacomas & 96-2002 4Runners 3 05-17-2004 05:37 PM
Rear Swaybar Bushing Questions CTB 95.5-2004 Tacomas & 96-2002 4Runners 11 11-12-2003 09:30 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
