recommend a terminal tool to remove wires from plugs
Anyone know of a brand/model that works on Toyota?
I have been Googling but nothing really seems to be Toyota specific that I can find.
Need to take apart a bunch of plugs with damaging the connectors on the interior of a 97 Runner and a 92 pickup
thanks
thanks
thanks
thanks
I just did one myself. I used the picks in the photo attached to this post:
BEGIN EDIT
http://www.milwaukeetool.com/Product...ordless+System
Sorry guys, wrong link. Here's the correct link:
https://www.yotatech.com/forums/f2/3.../#post51321834
END EDIT
Wasn't too bad. In the 'terminal' side, there was a white piece fo plastic that I 'drug' out first with a pick. Then, I used the small screwdriver to pry out the blue rubber plugs on the 'wire' side. Then it was back to the terminal side with the pick; there is a plastic tab above the metal terminal that holds it in. Got it out by using a combination move - prying up the tab with the pick while using the metal terminal as a fulcrum which simultaneously pushes the terminals back. The fall out through the round holes in the wire side.
Good luck!
BEGIN EDIT
END EDIT
Good luck!
Edited previous post to show this link:
steve miller
10-10-2015 01:40 AM
